What you're describing isn't an ignition switch problem, it's a problem of power not getting into the fuse block inside if nothing works in the interior. Check the fuses and connections labeled JB Power, if those are fine look at the BCM, and if that's fine look at the connections for the fuses behind the block. If there's something going on in the interior, the pcm might not supply power to the ignition switch, causing your problem. Electrical issues are always a pain, good luck.
