I need help!
My 2004 WJ was at the end of it's life and I really liked that series. Therefore, rather than buying newer, I picked up a 2001 WJ that was very well maintained, with much lower miles and wear than mine. However, the pervious owner piecemealed a 2.5" lift on it that makes it unsafe to drive. He took it to all the shops in Tulsa and nobody could figure out the issue. He sold it to me for $1500 and now it is my problem. On the front he put new longer springs, shocks, 1" longer sway bar links, 2" longer(lower) pitman arm on the steering box, and a 2.25" track bar frame rail bracket. On the back he put new longer springs, shocks, 2.25" longer sway bar links, and he put 2.25" worth of spacers between the differential and the upper suspension arm.
I think he did the lift a few years ago and has put on probably 50,000 mi since then. The ride is very soft (too soft) and there is body roll so that when it rolls right, it makes it yaw to the left causing you to have to steer right to compensate. You have to constantly adjust steering as you drive down the highway. The more people and weight you have in it the more worse the situation. I took it to a reputable alignment shop and they agreed with the previous owner that the jeep is properly aligned. They installed a new steering damper on it to see if that would improve the situation but it didn't.
My first question has to do with the 2.25" of spacer between the rear diff and the upper suspension arm. That seems odd and I don't see people doing that in lift kits. If the body is lifted 2.5" then I would think the lower and upper suspension arms should both angle down together. As it is, the lower is pointing more downward than stock, but the upper is angled more like stock. I would think this would fight eachother and put the rear axle in bind. Do people put spacers above the rear dif on 2-3" lifts or is that just an awful idea?
Concerning the springs, should springs on lift kits be stronger or weaker than stock? These seem to have lower spring constants than my 2004 that I still own or the 2000 that I owed previously. It certainly bounces more but I can't tell if it is shocks or springs that make it so soft feeling. I cannot find any markings on the springs or shocks that tell me what they are. The springs measure 0.600" whereas my stock rear springs measure 0.567" and my stock front springs measure 0.525". The rear springs have fewer wraps (5-6) compared to my stock rear (6-7) but the front has about the same number of wraps (8 or 9).
Finally, I think I want to replace the springs and shocks with something I know is reputable just so I know what is on there. I've looked at Old Man EMU OMEWJLKS. That's an expensive kit. Is there something out there a little cheaper that would be a good match for my situation? I could take it back to stock but I don't have any of the stock parts (unless I part out my 2004) and the track bar frame bracket was welded extra well by a 4x4 shop thinking that was the issue. It will take a lot of grinding to cut that thing off.
Thanks for any and all the advice you can give,
Steve
