1 - 6 of 6 Posts
Hello,
My old '90 XJ has an issue with its AW4 trans :
Everything begun with a roaring sound while driving. Nothing that scared me. I am used to new noises, and in generally it ends with removing some mud from wheels, brakes ... So I kept on driving ...
But, things went worse : 3rd speed refused to come ! When removing the TCM fuse, all 3 speeds pass easyly, but always with that roar on 3. No roar on 1/2.
Before that issue, the engine coolant boiled a little due to a too old water bottle cap, but the needle never went to the red line.
ATF 4 is clear, red, no smell, and the quantity looks ok. linkage seems OK.
When I go from "3" to "N" at the same speed (down hill), the roar stops. I a m pretty sure roar comes from tranny.
Any idea ?
Thank you for your help
Thank you very much !
I will try that and keep you informed.
Regarding, the fluid, there is a Jeep SB saying to use ATF4 in AW4. But maybe not with these old Cherokee's ?
Thank you Cruiser !:laugh2:
A little spray on these connectors, plus the TPS, and hop, the 3 goes on !
Now, I must find what is the cause of the roar ...
1 - 6 of 6 Posts
