1 - 3 of 3 Posts
Any help appreciated replaced oil pump drive cam & crank sensors & pcm computer. Ck engine light comes on almost as soon as started but idles & runs fine till 3200 RPM & cuts out & misses like it’s got a rev limiter.
Keep the original PCM !!
sounds like a CMP issue postt ALL codes.
did you use OEM CMP and CKP?
Do you have a scanner - to view live DATA and check the SYNC.
I'm thinking CMP not installed correctly, not timed to TDC or not within sync window.
PS 95 06 wranglers wit 4.0L have a CMP issue - maybe google for some insight.
Sorry for the delay been @ deer lease . As per your recommendation I put OEM cam & crank sensor back in & so far it’s been running fine. I already had sent OEM computer back but new has helped shifting & OD problems. The code reader was just saying cam pos & crank pos sensor. Thanks for your help hope it’s fixed drive almost 50 mi. & no code so far will let you know if problem comes back TAKE CARE MANY THANKS.
1 - 3 of 3 Posts
