I have a 2006 Jeep LJ Rubicon. I am experiencing the dreaded No Crank/No Start/NoGauges/No Fuel Pump/No OBDII Scanner connection issue. I’m at the end of my rope and unsure what to do.
I feel like I’ve checked everything. Good Battery, all grounds checked, all fuses and relays checked, ignition switch checked good, 12volts to the pink/orange wire in the start position, actuator pin not broken, the starter is good and will jump to turn the engine, New Wrangler Fix PCU with Skim disabled. Also, every engine sensor has been replaced on the Jeep in the last two years and I’ve tried unplugging the Crank Position Sensor and the Cam Position Sensor and there’s no change.
So the Jeep died back in August 2021. I let it sit and messed with it and finally pulled the trigger on a Wrangler Fix PCU in April 2022. I put it in and it didn’t start. So, I let it sit for about three weeks then one day I just decided to mess with it. I checked all the ignition/skim connectors and they all seemed fine. Weirdly, as I was messing with it the gauges came on and it started. I shut it off and started it several times and even drove it about for about 20 minutes. I figured it had to be a loose connection and I “fixed” it. I went out the next day and it was back to the no crank/no start/no gauges again.
I sent the PCU back to Wrangler fix to have it checked out and they said everything was fine.
I have gone back and checked everything I could think of all over again and everything seems fine.
Help! What else can I check?
By the way, I’m not a new forum member…but my account got corrupted and I had to create a new one.
