I'm running into and issue with my Jeep Wrangler it has over 200k on it and have tried to keep it in the best condition possible. Currently I was having issue with my check engine light blinking on and off and the engine and gauges would all blink off when it happen. From time to time my fuel gauge would not come back and show empty tank until I restarted the engine. I thought it my be a short and found that when I shook my ground wire from the battery it did have a short. Replaced that with the BIG 6 from JeepCables.com. It did not resolve my pending issue. Replace the fuel pump, nope did not fix.
Then when driving back my jeep just died and would not start. Let is sit for a few mins and it started back up and I made it home. The error code was P0016. Looked it up and read all about the OPDA issues. Ordered a Crown and when I went to remove the sensor the whole housing turned on me so I tried my best to get it back to position. The new senor I ordered from e-bay claimed it was OEM and even had the same marking as the old one but did not work. Put the old one back on and waited for the Crown to show up. I replace it with the help off this forum on how to and when I tried to fire it up my engine would hardly run and run like ****. I shut it down. I take it the timing was way off. The only option I had was to do the TDC and trust me that was a pain in the *** finding the markers as apparently you need to remove the belt to see it.
Once the markers were line up and did a stick down spark plug one to make sure it was top. I lined up the OPDA hole to center and move the housing so that it would be at the marked 4 o'clock position. I used the original sensor the first time. It fired up and rev the engine to 4K with no throttle down. I don't go any further than 4K and got the P0016 code shortly after. I disconnected the battery, unplugged the sensor, reconnected the battery and fired it up. This time it would only go to 3K before getting the throttle down safety. It popped the P0340 code. I disconnected the battery again and swapped the original sensor with the one that came with the Crown part and put it all back together. This time I rev the engine to 4K no issues but got the P0016 code again.
This point I'm running out of idea and this is where I turn to you guys for help. Thank you in advance.
