Did a search, but most of the threads are pretty old. Sister's '04 Grand Cherokee has no sound on right side door speakers, front and rear. I can't verify if they both failed at the same time or not, as she is not sure. It's possible that happened, but it's also possible that the rear may have failed first, then the front failed (or vice versa). And only after the second speaker failed did the problem become noticeable.
Either way, swapped in a JY head unit (actually 2 JY units), and the behavior is the same: no right side sound from either door, but the right side dash tweeter is working. Before I throw hours into this, I wondered if anyone has had experience with this before. My previous experience with speakers has been cone foam failures, not complete silence, so not sure if it's a speaker issue or harness issue I should start with.
Base model GC, Laredo, so I doubt it's the high end system, but I don't know for sure. If I dig through my garage to find a spare speaker to try, I'll post results here. Thanks for any help or any experience you've had in this regard.
