Yes another thread about no dash lights. I have read dozens of posts tonight trying to figure why mine went out. I think I know but need a second opinion.
Everything was fine! Should have let well enough alone but I didn't. I did two things to my Jeep today. 1st was the locker mod. Jumpered pins 1 and 4 by way of a switch. That works just fine. Can engage both front and rear in any T-case position. Second was to replace the Sony aftermarket radio with a JVC I had taken out of my truck I sold. The JVC has Bluetooth so I wanted to use it. The Sony didn't have an illumination wire but the JVC did so I hooked it up. All was working great until I turned on my headlights tonight. Just as soon as I turned them on I was looking at my mileage and saw it dim, go bright, dim, go bright, dim, etc.. for about 6 cycles. I then noticed I had no back lighting on my dash. Then about 30 seconds later I could smell something electrical. So I turned around and brought it home, disconnected the battery and started taking stuff off.
So far I know there are no blown fuses. The dim circuitry from the switch seems to be working cause the mileage does have varying levels of dimness as I rotate the switch. I also see a small changing voltage on pin 15 in the black connector as I turn down the dash lights, but I get no voltage at all from pin 6 in the same connector. If I found the right pin out, pin 6 should be dash lights and I am guessing that wire provides voltage to the AC knobs and the gear selector light. Looking at the back of the cluster, the right side smells burnt. And I correct in assuming the new radio (or the illumination wire getting hooked up) fried my cluster. And does the cluster actually provide the power to the rest the illumination items (AC controls, gear selector).
If so, where is a good place to get a cluster? I have looked on eBay and didn't see one. And are all 03 to 06 clusters the same whether it be a Rubicon or not?
