Thanks. I ordered new points, condenser, and rotor and hope to replace this weekend. I'll update when completed.If you go to Rockauto and look up a 1973 cj5 with 304ci they may be the right ones. Points start at $3.50.
You and me both! Thanks!Congratulations!!! Glad your Jeep is a runner again.
Many thanks to you!Excellent
What points gap are you using and have you then checked the static timing?
You are correct that removing the factory tach will cause it not to start. I’m removing the tach with the Speedhut gauge install — any suggestions on what I need to do to maintain this circuit?Factory tach? Amc ran the coil and icm power through the tach, so if you have taken out the factory tach, it will not fire.
I can’t find the plugs you’re referring to. The back of the tach looks like this. The wire nuts are me reconnecting so it will start.Unplug the two red wires originating from the factory tach and move them to the side. Then connect the remaining male and female plugs labeled "Tach Plug" in the pic below. That will complete the circuit minus the tach.
I hope that's clear.
Matt
So, apparently the tach harness has been hacked by a PO. As Fourtrail said, you can just connect the 2 white wires that are near each other together. That should complete the circuit with out the tach. The white wire that connects to the orange tach wire is for the tach light. You won't need that one, if you are eliminating the factory tach.I can’t find the plugs you’re referring to. The back of the tach looks like this. The wire nuts are me reconnecting so it will start.
Thanks for the tips. I swear I tried connecting the tach wires and had no luck. Just tried again and all is right in the world.You just have to connect the two wires that are next to each other together, that will allow power to pass to the coil. As for setting your point gap, I would set the running dwell as you have a distributor with external adjust-ability. Looks like the 304 should have about 30 degrees of dwell.
