What gauges did you buy? Some are not worth the effort to calibrate.
Anyway, you will have to make sure the the sending unit float has enough movement between a full tank and an empty tank otherwise calibrating the gauge would be pointless.
Take the sending unit out and using an ohmmeter make sure when you move the float up and down, you can go from 78 ohms when the gauge is sitting on the bottom and can read 10 ohms when the float it at the top.
Measure the depth of your tank and then make sure the float travels the same distance. Make sure when the float is all the way up, as if the tank is full, it doesn't drop below 10 ohms. It can go to 0 ohms which could burn out your gauges.
This should be good enough for for your gauges to operate properly but over time your gauges calibration can vary a little.
To take things a little further. One final adjustment....
MAKE sure you have a good ground in the remainder of this adjustment procedure.
If the ground falls off, things will get hot fast.
This is how I hook up the gauges for testing:
First lets have a look at the back of a typical OEM style Fuel gauge.
You probably never noticed the extra slots in the back but those are used for doing a calibration. They are actually quite clever in coming up with such a simple adjustment.
If you look inside an OEM gauge you will see two windings around two sperate bi-metalic strips. One is the often miss-labeled "Voltage Regulator" side and the other is for the needle or indicator movement.
As the windings heat up around the bi-metalis strip, one end of the strip will move.
This free end is attached to the needle. The way the calibration works is there is a slot in the end of the needle were the pin on the end of the bi-metalicstrip fits.
Depending upon the position of this pin in the slot determines how much the needle moves in relationship to the movement of BM strip.
The closer the pin is to the pivot of the needle the greater the travel of the needle.
This is the Full Scale Adjustment. So if your gauge is not reading "Full" when the resistance is 10 ohms then you need to adjust the position of the pin.
THe other adjustment just sets the starting position of the needle or "Zero Adjustment" So if your gauge isn't reading empty when it's at 78 Ohms then you need to change this adjustment.
Note these adjustment are interrelated meaning that if you adjust the "Zero Point", then the needle might not reach "Full" so you will have to go back and re-adjust the "Full Scale" adjustment.
Start with the Zero Point first.
I attached the proper resistance (73 ohms) to the "S" terminal and ground and attached the power and ground leads.
I used 10-32 nuts and wire lugs to make the connection easier.
Then I adjusted the Zero point to read "E" as best I could using a flat bladed screwdriver. Then you replace the 73 ohm resistor with a 10 ohm resistor and adjust the FUll Scale adjustment.
Note it might take a minuet for the needle to stop moving so you might want to read a chapter in your FSM while your waiting.
. It also makes several jumps when going to "F". This is normal.
Now the Crown replacement gauges I have work a bit differently. Mine was quite bent inside and needed an adjustment. Maybe yours was knocked out of cal also.
The Zero and Full Scale adjustment are in one place. Put the screw driver in one slot and you can adjust the Zero Position.
Turn the screwdriver 90* and you can adjust the full scale movement.
The pin and needle mechanism is the same as the OEM gauges. It's just they are made out of plastic instead of metal.
You may have noticed the screw on the side of the newer gauges. It is for adjusting the regulator. It controls the 'bounce' or 'steps' of the needle movement.
One way the needle moves in big jumps instead of moving slowly. Might not even reach 'full'. To far the other way and the regulator does not have time stop heating and the gauge moves too far or burns up.
This controls the Pulse Width Modulation 9PWM) of the regulator. Think of it as the 'voltage' adjustment even though it doesn't really change the voltage, just how long of a power pulse is applied to the heating coils on the regulator.
It has a funky screw so you don't accidentally mess up this adjustment.
the OEM gauges have a slot on the back and you have to bend the position of one of the points to adjust the regulator.
They have a nifty tool to make this adjustment that I only saw once on a picture on the internet and never again. It looks like a bent rod with a slot on the end so you can slip it in and bend the adjustment.
Irregardless of how the adjustments work internally, the procedure is still the same as above.
If you can't get the gauge to work properly after all this then I would recommend you send them back and get another set.
There have been some "Quality issues" with the vendor.
There are a couple of other types of after market gauges but I haven't needed to play with them yet. One is terrible and one didn't need any adjustment at all.
For more information on Gauges and stuff, Go here:
Quick Gauge test
Quick Gauge test
