Jeep Enthusiast Forums banner
Showcase cover image for Grand Cherokee WJ
General Information
Name
WJ Grand Cherokee
Year
2000
Model
Laredo
2000 WJ Grand Cherokee Laredo
Modifications
Suspension
Stock
Wheel and Tire
Stock-Timberline 245/75/R16
Engine
4.0L
Transmission
42RE
Future Modifications
Lift of some height tbd
Accessories
Pirate flag ziptied to antenna
Recovery Gear
None
Armor
None
Rear Axle
Dana 35
Transfer Case
242 Selectrac
Front Axle
Dana 30
Information
Purchased with blown radiator in March 2020. Had 147k miles at purchase, currently at 170k as of Nov 2021.
So far have replaced/done:
Radiator
Upper/Lower Radiator Hoses
Thermostat
Thermostat Housing
Water Pump (new one has metal impeller)
Valve Cover Gasket
Retorqued Head Bolts
Crankshaft Position Sensor
Cleaned IAC
Changed TPS
Replaced both front headlight housings
Replaced Driver side Tail Light Housing
Both CV axles on front end
Both wheel hubs on front
Caliper bracket on on front driver side
Passenger rear axle shaft bearing
Gas Filter outside of fuel tank
Power steering pump, pulley, High press line
Tensioner
Idler pulley
S-belt
Changed Battery
Replaced Vacuum Lines from CruiseCtrl Box to Intake
Added Fuel Rail Heat Shielding
Upgraded to 4pt Bosch Injectors
Dynomax Super Turbo Muffler
Rad Fan
Fan Relay (only have one)
Transmission Speed Sensor
Neutral Safety Switch
Lift support shocks for hood/rear windshield
Gas Cap
Windshield replaced due to large unfixable crack.
Wear Items:
- Oil changed every 3k miles, used valvoline high mileage synthetic oil and Wix XP filter.
- Brakes replaced on front and back, had to replace driver side caliper bracket as the grease evaporated and seized one of the pins in the bracket. Brake bleed fixed the issue.
- Front and rear diff fluid changed every 12k miles
- Replaced Transmission filter with Mopar filter and changed fluid but did not do flush.
- Have to change wiper blades every 6 month or so
- Tires changed summer of 2020 with used tires, still have good tread depth left.
Gallery
Comments
There are no comments to display.
Top
