Jeep Enthusiast Forums banner
Forum Discussions about this Product
1 - 3 of 3 Posts
    1. · Registered
      Joined
      Find an 01 that is wrecked, get the front seals off of it. Then go get a bottle of rubber conditioner like Gummi Pflege Stift, clean them and then treat them. NO NOT USE ARMOR ALL. It's full of silicone which will break down the rubber.
    1. · Registered
      Joined
      I had the same problem with my sunroof squeaking. I thought for sure it was the frame. Turned out it was the seals. The seals are not lubricated from the factory. I purchased on Amazon a bottle of Gummi Pfledge. I used it to lube all the seals in the sunroof and haven't had an issue since. I drive a lot of gravel roads that caused it to squeak, so I was grateful to solve the problem so cheaply. Link: nextzett 91480615 'Gummi Pflege Stift' Rubber Care Stick - 3.4 fl. oz https://www.amazon.com/dp/B004B8GTQG/ref=cm_sw_r_cp_api_ceh8xbQXKGM83
    1. · Registered
      2021 Jeep Grand Cherokee L Summit
      Joined
1 - 3 of 3 Posts
Forum Reviews
Be the first to review this product
Write a Review
Do you have experience with this item? Help our community members and share your knowledge.
Sign in to add review
Top
