You will have to remove all the hardware for your softop. You can re-use the nuts and bolts from the side rails , and the sheet metal screws from the windshield channel. get yourself some weatherstripping for the sides. If your Hardtop does not have the larger rubber seals in the front corners, you may wanna try and pick some up. I'm sure you can probably get them through Quadratec or go here:
http://cgi.ebay.com/ebaymotors/New-...001QQitemZ110022086830QQrdZ1QQsspagenameZWD1V
Quadratec sells these kits, but it is really just some weatherstipping you can get a the local Hardware store or HomeDepot.
http://www.quadratec.com/products/13022_50.htm
They also have these reinforcement kits, but I don't know how well they work. Anyone had any experience with this??
http://www.quadratec.com/products/13022_101.htm
