Jeep Enthusiast Forums banner
Forum Discussions about this Product
1 - 9 of 9 Posts
    1. · Registered
      Joined
      i am installing a JVC single DIN radio in my 2004 WJ.
      Besides the faceplate bezel (Metra), what else do I need to interface it with the existing infinity amp and the control buttons on the steering wheel?
      I think I need the AXXES ASWC-1 - but...dont the make a cable with a connector at both ends that will fit the JVC radio and the factory connector to the amp?
      I also think I need a box to talk to the steering wheel switches. Who makes them? Which one is a good one?
      Thanks
      J
      this is all you'll need
      steering wheel control:
      https://www.crutchfield.com/p_120AS...uUKyOgB2Hbu3LPwHO-ree94QdehbkSvAaAqxLEALw_wcB
      harness:
      https://www.amazon.com/Stereo-Harness-Cherokee-wiring-installation/dp/B000KL4MG2
      Sent from my iPhone using Tapatalk Pro
    2. · Registered
      Joined
      Discussion Starter · #5 ·
      thanks...so here is where it is not clear. The harness has a plug on one end...I assume that the plug is inserted into the socket that goes to the infinity amp...but...how do I know what connections to make on the other end?
      I assume it is to be connected to the wires on the JVC supplied dongel, but I cannot find instructions for connecting them.
      Guidance please?
      Thanks
    1. · Registered
      Joined
      Most 3rd party head units will work with the infinity system (AFAIK). Aftermarket head units require an 'adapter' to match the signals out of the head unit to the plug of the infinity system. Here is the adapter for the head unit I got
      http://www.metraonline.com/part/Chrysler_wire+harness_70-6502
      To maintain the steering wheel control capability requires buying an adapter. Here is one that I have used and works fine:
      https://www.crutchfield.com/p_120ASWC1/Axxess-ASWC-1-Steering-Wheel-Control-Adapter.html
      I have not noticed any interaction with the preset seat or mirror positions.
    2. · Registered
      Joined
      That Axxess adapter, any issues to watch out for? I wanna install a headunit in mine and was wondering which adapter to use. Did you just match wires? :popCorn:
    1. · Registered
      Joined
1 - 9 of 9 Posts
Forum Reviews
Be the first to review this product
Write a Review
Do you have experience with this item? Help our community members and share your knowledge.
Sign in to add review
Top
