Jeep Enthusiast Forums banner
Forum Discussions about this Product
1 - 10 of 29 Posts
    1. · Registered
      Joined
      Discussion Starter · #3 ·
      well I was looking at buying this SYE, along with this CV drive shaft. My overall plan was to put a 4.5" Rubicon Express lift with Warrior 1.5" lift shackles. I thought I might ask and see if it would be cheaper to get it lengthened, but I guess it would be better to go with a SYE and a CV DS....
    2. · Registered
      Joined
      when it comes to your driveline its kind of important to do it right. lets look at this in two parts.
      first, the benefits of the SYE (Slip Yoke Eliminator kit)
      1. the kit replaces the factory output shaft with a shorter and generally beefier unit
      2. the new tail cone and yoke will seal the transfercase. Why is this good? if and when you throw or break a rear driveshaft or u-joint, you can drive the Jeep in 4wd (front wheel drive) to get it home. you cant do this without the SYE as the slip yoke on the drvieshaft is the only thing keeping the fluid in the t-case. without it, you will be puking fluid all the way home and will likeley destroy your T-case. trust me, it happened to me.
      3. the SYE kit will usually come with all new seals for the t-case.
      4. the SYE will allow you to run a longer driveshaft. this will cut down the driveline angle, thus reducing vibrations and u-joint wear and tear. I was lifted with 3.5"s of suspension and 2" shackles, right the suspension height you are looking at. I did not do an SYE intiially. I was blowing a rear u-joint practically once a week, and as I said, from driving it in front wheel drive with no means of keeping the fluid in, I grenaded my t-case.
      Now the benefits of the CV driveshaft
      1. basically when you do the SYE, you need to change to a CV shaft with a slip joint on the shaft since you are eliminating the slip yoke. the driveshaft needs to be able to extend and collapse as the suspension travels.
      2. With the CV shaft, the CV joint will overcome any additional angle issues you may have, and with that much suspension lift, you will need it. the benefit is you should not have any vibes from the rear driveline.
      below is a picture for reference. these are both front CV driveshafts from a Jeep cherokee XJ. these are a good option because they are relatively strong, they are cheap and easy to find in most junkyards, they use the same u-joints that your YJ uses, and most shaft shops will cut them down for you for around 50 bucks. the top one in the picture is the one I use in my YJ, the bottom one is stock length. you can see the difference between these and your stock shafts.
      I hope this helps, and if you have any more questions please ask
    1. · Premium Member
      Joined
      What else do you have to fit the 35" tires on the 4" of lift?
      Do you have an SYE (Slip Yoke Eliminator). Do you have a T-case drop. Do you have long or short arms? Do you have combo body-lift / suspension lift to fit the 35" tires or is it all suspension?
      From there, we might be able to help a bit more. :thumbsup:
    1. · Registered
      Joined
      Getting a SYE would be the best thing to do, next to getting a t-case drop. Before I didn't care and told myself: "I don't need a SYE, who needs that little extra clearance?"; Last time I went rock crawling I left a nice gash on my t-case skid and I'm almost certain it never would've happened if I had a SYE.... and a good spotter! haha
      http://www.quadratec.com/products/52301_910.htm
      http://www.quadratec.com/products/52237_99_07.htm
      http://www.quadratec.com/products/16066_00.htm ( body lift recommended )
    1. · Registered
      Joined
      Discussion Starter · #1 · (Edited)
      I need some advice on purchasing a slip yoke eliminator for my 01 tj sport I-6 with d44 rear. Ive recently bent the output shaft on the transfer case and I have been having trouble identifying what model of transfer case i have. I was going to put a slip yoke eliminator on to not only fix my problem but prevent it from happening again.
      Ive only found 2: Omix-Ada, Advance Adapters
      Also what all is involved in installing the slip yoke eliminator? What drive shafts work best with which sye? And roughly how much am i looking at spending in parts?
      Edit: Any full kits including the drive shaft other then the Full Traction kit?
    2. · Got Sand?
      Joined
      If your Wrangler has the factory transfer case, it's an NP231.
      I bought the Advance Adapters one for a little less than $200.
      From Stu-Offroad: TJ SYE Installation
      Any proper length double cardan driveshaft (often mistakenly called a CV driveshaft) will work.
      How much you spend is up to you. Google is your friend.
    1. · Administrator
      Joined
    1. · Registered
      Joined
      Discussion Starter · #48 ·
      Alright, guys... Here's my plan, tell me if I'm way off here.
      Advanced Adapters SYE kit: http://www.quadratec.com/products/52237_99_07.htm
      Tom Woods DS, Quadratec has one, but not sure if it's a CV or not. It looked like it might be, but it might be worth calling TW's shop instead. http://www.quadratec.com/products/52301_901_07.htm
      And if I can find Bersk I'll get a set of his shackles, if not I'll buy the 1" lift shackles from BDS. I've got a set of jackstands and a floor jack now, so hopefully I can do part of this on my own.
      When the SYE and DS go in, the t-case drop will be pulled off.
      Thoughts?
    1. · Registered
      Joined
      I have an 87 4 cylinder. 1" body, 2" suspension and 1" shackle lifts. I am almost finishing my prep on the 8.8 i got for $100. I got a front shaft out of a '98 Grand Cherokee for $20(needed a new spicer) So before I have the 8.8 welded up I need (or want) to install an SYE. Which one do i go with?
      http://www.thejeephut.com/np231-sli...-kit-1988-2006-jeep-wrangler-by-rugged-ridge/
      http://www.4wheelparts.com/Drivetra...aspx?t_c=12&t_s=512&t_pt=7779&t_pn=TER4444400
      There are others, I just didnt put them here. I am looking for a middle of the road; not the best and not the worst.
      So many to choose from?
      Are there kits for the spring plates and shock mounts that i need? What else should I be looking for?
1 - 10 of 29 Posts
Forum Reviews
Be the first to review this product
Write a Review
Do you have experience with this item? Help our community members and share your knowledge.
Sign in to add review
Top
