Jeep Enthusiast Forums banner
Forum Discussions about this Product
1 - 10 of 101 Posts
    1. · Registered
      Joined
      05 Unlimited
      Here is my 2005 Unlimited with the 4" Rough Country X Series kit installed. Falken Wildpeak 315x70x17 AT's on JK Wheels
      More to come, I just bought this thing.
      One suggestion. Find a work around for the rear shock bolts that will break in salty climates.
      http://www.roughcountry.com/jeep-suspension-lift-kit-661.html
    2. · Registered
      Joined
      turpehar said:
      Here is my 2005 Unlimited with the 4" Rough Country X Series kit installed. Falken Wildpeak 315x70x17 AT's on JK Wheels More to come, I just bought this thing. One suggestion. Find a work around for the rear shock bolts that will break in salty climates. http://www.roughcountry.com/jeep-suspension-lift-kit-661.html
      LJ's look so damn good on 35s..
    3. · Registered
      Joined
    1. · Registered
      Joined
      Discussion Starter · #104 ·
      osmosiz ive looked at seemingly 100 different 4 inch lift setups and i was wondering what setup you went with and how its working out. you seem to put yours to the test which i definately am going to do. i was also wondering if you did any body lift at all and if your tires were actual 33 1250s or a metric equivelant. again thanks for the help and im diggin your tj!
      hey thanks man, BTW Welcome to JF! im running the rough country lift..
      http://www.roughcountry.com/jeep_tj_4.html
      its alright, i didnt get the 2.2 shocks so mine are kinda stiff, and the arms that it comes with are only the lowers and their fixed, after about 2 months they start making noises and i always have to keep checking them to make sure there all torqued properly. on the plus side, it does get the job done. eventually im going to replace all the arms with some adjustables.
      there is a better lift that RC makes:
      http://www.roughcountry.com/jeep_tj_4x.html
      but its a little more pricey. i have no problem recommending RC's products to anyone, ive been running them for almost a year and ive certainly put them to the test. its a great starter kit... something you can build off of.
      As far as a body lift, i dont need one right now for my 33x12.5x15. which with a 7 inch wide rim so it measures out to 34x11.5 .. also i run the spidertrax spacers so theyll fit with my stock rims. eventually ill get a 1 inch body lift when i run 35's but for now im good.
    1. · Registered
      Joined
      The new X-series Kit was designed to be a tough, great performing kit at a market leading price. The new lower arms are a heavy 1/4 thick DOM and Solid DOM uppers with a X-Flex Joint. Kit is Priced at a Intro Price of $999 and includes:
      (4) Flexy Coil Springs made in the USA
      (4) Lower X-Flex Control Arms
      (4) Upper X-Flex Control Arms
      (4) Shocks (upgrade to 2.2's)
      New High Flex, Ajustable 1/4" Wall DOM Front track bar and bracket
      Drop Pitman Arm
      Rear Track bar bracket (optional rear adjustable)
      Front Disconnects, Rear Extented Links
      Front & Rear Ext. SS brake lines
      Also, products are covered by our "We will fix it" warranty. If it breaks... we will replace it.
    2. · Registered
      Joined
      Drop Pitman Arm
      I haven't heard anything bad about their new components...and, I almost bought this Jeep. Just saying...
    1. · Registered
      Joined
      Discussion Starter · #1 ·
      hey guys :wave: so i need to see some rigs with 4" or 4.25" lift kits or combos with 33's.. im thinking bout going down this road but gotta see some pics and get some info and feedback.. THNKS GUYS!! :2thumbsup:
      im debating on either doing a 4 inch lift kit:
      RC X-SERIES 4" KIT
      RCD 4" KIT
      Or any other 4 inch kit suggestions u guys have...
      OR......
      A 3" kit with either a 1" or 1.25 combo kit:
      Zone 3" kit with combo if u press the combo tab off this page, Zone combo
      bds 3" kit the add on a bl
      any other suggestions u guys have..
      Keep in moind im prob only going to do a basic kit because i dont have a huge budget, moderate wheelin (trails, some mud, basic stuff really) and i want it to look sickk.. this is my daily driver as well..
      THANKS IN ADVANCE FOR THE POSTS.. BRING ON THE PICS/INFO!!! :2thumbsup:
    2. · Registered
      Joined
      Discussion Starter · #39 ·
      hey guys, so i think i am going to go with the rc 4" x-series kit.. it looks like a great deal, good lift, perfect for what i want to do with, and if i end up going to 35's eventually, i will already be equipped..
      BUT..
      now i am wondering if i should look away from the regular RC 4" x-series kit and go with the RC 4" x-series LONG ARM kit..
      Yea im DEFINITELY going to go with the long arm kit for a couple hundred more i think.. WHY NOT!?
      PLEASE LET ME KNOW WHAT U GUYS THINK!!
    1. · Registered
      Joined
      http://roughcountry.com/jeep_tj_4x.html
      Best value 4" kit to me. 8 adjustable flex arms, front adjustable trac bar, discos, springs, shocks, extended brake lines, etc. RC also offers a 10% discount to jeep forum members.
      You should be able to get a CV driveshaft with the cash you have left over.
1 - 10 of 101 Posts
Forum Reviews
Be the first to review this product
Write a Review
Do you have experience with this item? Help our community members and share your knowledge.
Sign in to add review
Top
