Jeep Enthusiast Forums banner
Forum Discussions about this Product
1 - 10 of 16 Posts
    1. · Registered
      Joined
      I recently replaced mine and got it for $21 at Advance auto parts. Surprisingly it's actually much beefier in construction than the OEM one.
      If you plan on replacing it yourself no standard ball joint puller will fit in that area and no pickle fork will even get it to come off. I would highly suggest to get a ball point joint separator like this one:
      3/4" Forged Ball Point Joint Separator
    2. · Registered
      Joined
      That's strange, I was able to do mine with the loaner from Autozone?
    1. · Chicken in a Turkey Suit
      Joined
    1. · Registered
      Joined
      Also, if you're putting force on it with a puller/separator and heating it up, it will help to tap lightly on the drag link around the stabilizer stud. Force and heat will beat it, and vibration can help coax it along.
      Keep clear of the exit path, they can let go with dangerous force.
      I grabbed this BJ separator a couple weeks ago to do my stabilizer, and I've also used it on both front sway links. I'll never go back to beating on joints after doing it this way. Faster, easier, and less cursing. :thumbsup:
      Good luck!
    1. · Registered
      Joined
      Discussion Starter · #1 ·
      I'm going through the front-end of my 1998 TJ Sport (D30F, D44R) and figure I may as well post my tribulations; getting this stuff documented, in as much detail as I can remember, may help someone (even myself!) in the future.
      This all started with my 1998 TJ track bar removal - JeepForum.com thread.
      At this point I've had the tires Road Force balanced, and the wobble/shimmy is gone. There's still some vibration, some of it may be due to inherent tire vibration (31" BFG A/T KO) but I've got 138K miles at this point so I want to make sure I don't have any worn parts in the front-end. I've also been very neglectful of greasing all the fittings over the years so I figure it's high time I start taking better care of my Jeep.
      So, next I used a pry-bar jammed into various places in the front end and tried to move the ball joints and u-joints by hand. Everything seemed tight, except for the front passenger side axle U-joint. There was a little (about 1/8") movement in it. Also, when I greased the steering knuckle joints where they meet the tie rod and drag link, the grease boots (which were pretty dried up) burst. Great, so now I'm spitting grease right at my brake rotors.
      I already have a box of Energy Suspension 9.13101R boots that I never installed (except for 1), so I plan to install 2 of these (1 at each end) and get them pumped up.
      I remove the wheels and brake calipers.
      Note: while removing the wheels the last several times, I've noticed that the wheel studs (the bolts on the hub where you screw down the lug nuts) seemed to be getting worn to the point where it was difficult getting some of the lug nuts/wheel nuts on. I always thought that these studs were integral with the hub assembly; when I pulled the wheels this time, some of the threads got mangled quite severely, and I couldn't get nuts back on anymore. I went out and purchased SAE / Metric Tap and Die Set - 60 Piece, Alloy Steel at Harbor Freight. Once I got home I searched online for some tips on rethreading. That's when I came across: How to Replace Lug Nut Studs : Removing a Broken Lug Nut Stud - YouTube and discovered that these studs were individually replaceable. What a relief! I'm not sure yet if I'll keep the tap and die kit, or return it... I may never have a need for it, but it's one of those things that I feel I might find random uses for in the future. I'm open to suggestions here. :)
      I found that Advance Auto had replacement wheel studs for $1.99: Dorman part # 98169.1. (The D44 rear studs are part # 97000.1, I picked up a couple of those as well for later.)
      I tried pressing the old studs out with a cheap C-clamp and a socket but I couldn't get a good hold on the ends of the stud, so I got frustrated and ended up just resorting to the hammer method as shown in the video. 2-3 whacks with a framing hammer, and the stud was gone; repeated for another stud.
      To get the new studs installed, I basically used the method shown here: How to Replace Lug Nut Studs : Preparing a New Lug Nut Stud Surface - YouTube . I bought a giant hex nut at Ace Hardware and used that as a spacer, and a regular hex nut and washer as a puller. (Wheel stud specs are: 1/2"-20, btw.)
      This worked great, except after doing the first one I found that the threads on the giant hex nut (because it was difficult to perfectly center around the stud) slightly chewed on the brand new wheel stud's threads. For the next stud, I just used an oversize washer (5/8" i.d. fender washer I think) as the spacer, with a 1/2" i.d. fender washer on top of that. This actually worked VERY well, no thread damage. If I had to do it again I'd probably go with 2 of the 5/8" washers to provide a little more clearance depth for the shoulder of the stud to pull through.
      I also bought 10 new wheel nuts at Advance Auto, made by Dorman, I'll post the part # later (TODO). They were $2.50/ea. So now I have no issues getting the nuts threaded back onto the hubs.
      While I was doing all this, btw, I noticed a Rotational stiffness in front left wheel - JeepForum.com; i.e., a binding when turning the driver's side hub which I'll address later (I haven't resolved this yet).
      So, after all that, I finally got to pulling the tie rod to replace the boot. I got it loose with a lot of PB Blaster, a 3/4" socket, and a 25" breaker bar. I left a few threads on the stud so it wouldn't drop to the ground, and tried pulling it out with a 2-jaw puller. The puller kept slipping off though, so I used a 3/4" Forged Ball Point Joint Separator I got at Harbor Freight. After a bunch of cranking there was a huge explosion and the sound of a bunch of small pieces hitting the ground; fortunately it was just bits of rust and crud -- the tool was intact and the joint had been separated. Next I crammed a pry bar through the axle yoke to suspend the TRE while I cleaned it up: I removed the old boot/seal by grabbing around the circumference with a large pair of pliers, and twisting and turning. Then I pumped some clean grease through it, wiped it down, put the new boot on, and reinstalled it (35 ft-lbs). This was after wire-brushing the scale off of the flange that it mounts through. I also used a new castle nut (a.k.a. "slotted nut") and cotter pin from Ace Hardware, as the old ones were rotted.
      Speaking of the cotter pin, I also had a hard time getting these out since they were so rusted. I ended up clipping the "loop" end with a pair of side cutters, and pulled the individual segments of the straight pieces backwards through the stud with a pair of pliers.
      On to the passenger side: still haven't been able to get that nut loose, and couldn't get the whole cotter pin out. It's all rusted together SEVERELY. Still working on that one. The castle nut corners are rounded off at this point. I tried using a 1/2" Drive Stud Extractor but so far all this has done is chew into the nut.
      My next step will be to use a hacksaw to cut vertically (against the edge of, and parallel to, the side of the stud) through the nut and see if I can just chop it off, hopefully without damaging the stud threads. I haven't been able to get a nut splitter anywhere (all the local stores are out, and HFT discontinued theirs) so I'm not sure what else to try at this point.
      More to come....
    1. · Registered
      Joined
      I was pretty happy with the Moog I just installed a few weeks ago. Seems to have worked out pretty well. I was also really happy with this guy:
      http://www.harborfreight.com/3-4-quarter-inch-forged-ball-point-joint-separator-99849.html
      Grease the heck out of the screw and contact before using it though, and stay clear of the joint you are separating. When mine finally popped, it seemed like it exploded out from the built up tension, and I had to count body parts and check my shorts before I continued working. Think about what direction it is going to fly when it comes apart and make sure you aren't there.
    1. · HIP2BSQR
      Joined
    1. · Registered
      Joined
      My yj needs all sorts of pullers and presses. Puller and press for ball joints, puller for tie rod, press for u-joints, puller for pulleys, etc.
      Best style of TRE/ball joint separator:
      https://www.bavauto.com/catalog/product/view/id/388919/
      https://www.harborfreight.com/3-4-quarter-inch-forged-ball-joint-separator-99849.html
      Loosen the castle nut, insert tool, lube up the tool's threads, crank it until it is tight, smack the side of the joint. Pop. Half the time, it pops before you get a chance to smack it.
      Way better than a pickle fork. Does not mess up the rubber boot like a pickle fork.
    1. · Registered
      Joined
      Having just replaced a drag link...
      The link should be rotatable by hand but should be pretty stiff. There should be NO movement at the threads. If it rotates at the threads, it can cause wear and potential failure (this was the issue I faced). Have someone rock the wheel and confirm there is no lateral movement at either ball joint end.
      If you do wind up dropping the drag line (or tie rod), I recommend a puller like this. Very easy to use, fits in small places.
1 - 10 of 16 Posts
Forum Reviews
Be the first to review this product
Write a Review
Do you have experience with this item? Help our community members and share your knowledge.
Sign in to add review
Top
