Jeep Enthusiast Forums banner
Forum Discussions about this Product
1 - 2 of 2 Posts
    1. · Registered
      Joined
      I want to start buying the tools I will need for rebuilding/ re-gearing my differentials, I have a FMS that tell me all the special tools that I will need and I know that I can buy them from millerspecialstools.com. The only problem is that they are so expensive. I haven't asked matco or snap-on dealers in my area. Does any body know where I can buy these tools for a bit cheaper.
      Thanks.
      I just installed gears in my TJ.
      Every thing I needed I got from Harbor Freight.
      Large earring puller Large Bearing Separator
      Magnetic base Multipositional Magnetic Base with Fine Adjustment
      6" Calipers 6" Digital Caliper
      Dial Indicators 1" Travel Machinist's Dial Indicator
      In top of that basic hand tools and a die grinder to make a set of set up bearings and you have everything you need to get install a set of gears.
      Enjoy.
      Troy
    2. · Registered
      Joined
      Enjoy.
      Troy
      I used these as well re-gearing my Cherokee a few weekends ago.
      I also used their hydrolic press quite extensivly - couldn't not have done it without that.
      I needed a digital micrometer for measuring shims accurately. I used this rather than calipers.
      A nice to have tool was the harbor freight seal and race driver but not needed.
      I needed an inch pound bar torque wrench along with adaptors to go up to 1/2" drive for it to fit the pinion socket and check that preload.
      A dremel to make setup bearings especially in the front end.
      The master install kit came with my gear marking compound, and new bearings - I used my old ones as the setup bearings.
      Whiskey
1 - 2 of 2 Posts
Forum Reviews
Be the first to review this product
Write a Review
Do you have experience with this item? Help our community members and share your knowledge.
Sign in to add review
Top
