Jeep Enthusiast Forums banner
Forum Discussions about this Product
1 - 9 of 9 Posts
    1. · The Guru of Nothing
      Joined
      Discussion Starter · #1 · (Edited)
      *All Available XJ Suspension Systems*​
      Alright so heres the story, I realized that there are a lot of posts on this forum asking What kind of kit should I get? Where should I get it from? What are the Prices? So I decided that I should sit down and put a list together of what is out there and roughly what they come with. Well it turns out that it took me about three sittings to get it all finished up and im sure that I didn't finish everything. So I hope that you guys enjoy this and please by all means let me know if I have something wrong or if im missing a lift. Thanks for putting on a great forum guys and I hope that this helps out some people.
      *Please Note*
      1. The available tire clearance for each lift does not include any trimming that may be done. Those suggested sizes are for stock fenders and you have the potential to get a much bigger tire size if you do a little trimming.
      2. The links provided are not necessairly the best available prices but instead links to give an example as to what the exact lift is that your looking for.
      3. For all Jeep Forum members there is a coupon code that we can use while shopping at Jeepin Outfitters, this code is JFM05
      How To Install A Lift On A XJ
      http://www.jeepforum.com/forum/showthread.php?t=404101
      How To Install A TC Drop On A XJ
      http://www.jeepforum.com/forum/showthread.php?t=405578
      All Available Shackle, Coil Spacer, And Budget Options
      http://www.jeepforum.com/forum/showpost.php?p=3556446&postcount=1
      Everything You Need To Know About A Leaf Conversion
      http://www.naxja.org/forum/showthread.php?t=27835
      2-2.5 Inch Lift Options
      RE6160 XJ 2" Budget Boost w/shocks
      Tire Clearance: 30x9.50
      Includes: Break Lines, AAL, Spacers, and Shocks
      http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=112
      OME 2" Suspension Kit, Cherokee, 1984-01
      Includes: Bumpstops, Full Leaf Packs, Coils, Shocks, JKS Quicker Disconnects
      http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=645
      Superlift 2.5" Suspension lift, Jeep XJ Cherokee
      Includes: Coils, Lower link arms, AAL, and Shocks
      http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=781
      Rustys 2" XJ AAL Kit
      Includes: Coils, AAL, and Shocks
      http://rustysoffroad.com/mm5/mercha...s&Product_Code=200AL&Category_Code=sus_xj_kit
      Rough Country 1.5" Suspension Kit
      Includes: Coils, Shackles, and Shocks
      http://www.roughcountry.com/jeep_xj_1.html
      Rock Lizard Fabrications 2" AAL Kit
      Includes: Coils, Long AAL, Leaf Spring Clamps, Center Pins, and U-Bolts
      http://www.rocklizardfabrications.com/lizard_lift_kits.htm
      Rock Lizard Fabrications 2.5" Leaf Pack Kit
      Includes: Four Leaf Spring Pack, Coils, Long AAL, Spring Isolators, Spring Clamps, Center Pins, and U-Bolts
      Skyjacker 2 in. Poly Value Kit
      Includes: Poly Spacers, Bumpstops, Shackle and Nitro Shocks
      http://www.4wheelparts.com/PDT55375.aspx
      Rustys 2" Budget Boost w/Shackle
      Includes: Poly Spacers, and Shackle
      http://rustysoffroad.com/mm5/mercha...s&Product_Code=XJ-B1&Category_Code=sus_xj_kit
      Rustys 2" Budget Boost w/AAL
      Includes: Poly Spacers, and AAL
      http://rustysoffroad.com/mm5/mercha...s&Product_Code=XJ-B3&Category_Code=sus_xj_kit
      3-3.5 Inch Lift Options
      RE6030 XJ 3.5" SuperFlex kit w/leafs
      Tire Clearance: 31x10.50
      Includes: Gen2 Disconnects, Coils, Bumpstops, Leaf Spring Pack, Rear break line, U-Bolt Kit, and LCA
      http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=115
      RE6010 XJ 3.5" SuperFlex kit w/aal's
      Includes: LCA, Coils, Bumpstops, AAL, and Shocks
      http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=120
      RE6025 3.5" XJ Super Ride w/ Rear Springs
      Includes: LCA, Full Leaf Packs, Coils, and Rear Break Line
      http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=219
      RE6020 3.5" XJ Super-Ride Kit
      Includes: LCA, AAL, Coils, and Rear Break Line
      http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=218
      OME 3" Suspension Kit, Cherokee, 1984-01
      Includes: Shocks, Full Spring Packs, Coils, and JKS Quicker Disconnects
      http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=429
      Rustys 3" Spring Pack Kit
      Includes: Coils, Full Spring Packs, Break Line Relocation Kit, and Shocks
      http://rustysoffroad.com/mm5/mercha...s&Product_Code=300SP&Category_Code=sus_xj_kit
      Rustys 3" XJ Add-A-Leaf Kit
      Includes: Coils, AAL, Break Line Relocation Kit, and Shocks
      http://rustysoffroad.com/mm5/mercha...s&Product_Code=300AL&Category_Code=sus_xj_kit
      Rough Country 3" Suspension Kit, Full Spring Pack
      Includes: Coils, Full Spring Pack, and Shocks
      http://www.roughcountry.com/jeep_xj_3.html
      Rough Country 3" Suspension Kit, AAL
      Pro Comp 3" Suspension System
      Includes: Coils, AAL, Break Lines, LCA, and Adjustable Shocks
      http://www.4wheelparts.com/PDT1764.aspx
      Includes: Coils, AAL, Break Lines, LCA, and Non Adjustable Shocks
      http://www.4wheelparts.com/PDT1566.aspx
      Rancho 3 in. Suspension Kit with RS5000Shocks
      Includes: Coils, Full Leaf Pack, and Shocks
      http://www.4wheelparts.com/PPT3657T5491.aspx
      Skyjacker 3 in. Standard Kit w/AAL
      Includes: Coils, AAL, and Hydro Shocks
      http://www.4wheelparts.com/PDT54900.aspx
      Skyjacker 3 in. Standard Kit w/ Full Spring Pack
      Includes: Coils, Full Spring Pack, and Hydro Shocks
      http://www.4wheelparts.com/PDT55240.aspx
      Full Traction 3.5" Kit
      Includes: Coils, Quick Disconnects, Rear Break Line, Dual Rear Leaf Inserts, and Control Arms
      http://www.full-traction.com/detail.php?MODELID=4&MAKEID=1&TYPEID=1&PRODUCTID=97&NOTES=20
      Warrior 3" Suspension Kit
      Includes: Shocks, Shackles, Coils, AAL, Sway Bar Link, Tie Rod Bracket, and LCA
      http://www.discountjeepparts.com/pr...18109?osCsid=b1ddede67daec307cc3b0a2381eb6115
      Rock Krawler 3" Suspension Kit
      Includes: Coils, AAL, Adj Front Trac Bar, Trac Bar Relocation Bracket, Drop Pitman Arm, Sway Bar Discos, and U Bolts
      http://www.tellico4x4.com/product_info.php/cPath/3601_3603_3608/products_id/28396
      Black Diamond 3" Suspension Kit w/ AAL
      Includes: Coils, Shocks, Full AAL's, and LCA's
      http://www.4wheelerssupply.com/catalog/product_info.php/products_id/1581
      4-4.5 Inch Lift Options
      RE6130 XJ 4.5" SuperFlex kit w/leafs
      Tire Clearance: 32x11.5
      Includes: Coils, Full Spring Pack, Bumpstops, Front Track Bar, LCA, Rear Break lines, and RE Gen2 Disconnects
      http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=113
      RE6111 XJ 4.5" SuperFlex kit w/AAL
      Includes: Coils, AAL, Bumpstops, Front Track Bar, LCA, and Break Lines
      http://www.jeepinoutfitters.com/scripts/prodList.asp?idCategory=62
      Superlift 4" RockRunner lift kit, Jeep XJ Cherokee
      Includes: Coils, Full Spring Pack, Shocks, Upper and Lower axle links, Front Track Bar, and Quick Disconnects
      http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=783
      Superlift 4" Standard lift kit, Jeep XJ Cherokee
      Includes: Coils, Full Spring Pack, Shocks, Front Track Bar, Upper and Lower axle links, and Quick Disconnects
      http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=782
      Rustys 4.5" XJ Spring Pack Kit
      Includes: Coils, Full Spring Pack, Shocks, LCA, Break Lines, Front Track Bar, TC Drop Kit, and Front Sway bar Extensions
      http://rustysoffroad.com/mm5/mercha...ys&Product_Code=405K&Category_Code=sus_xj_kit
      Rustys 4.5" XJ Add-A-Leaf Kit
      Includes: Coils, AAL, Shocks, Rear Shackles, LCA, TC Drop, Brake Lines, and Sway Bar Extensions
      http://rustysoffroad.com/mm5/mercha...s&Product_Code=405AL&Category_Code=sus_xj_kit
      Rough Country 4.5 Suspension Kit w/AAL
      Includes: Coils, LCA, TC Drop, Front track bar drop bracket, Swaybar links, Brake lines, Shocks, AAL, and Shackles
      http://www.roughcountry.com/jeep_xj_4.html
      Rough Country 4.5 Suspension Kit w/ Full Spring Kit
      Includes: Coils, LCA, TC Drop, Front track bar drop bracket, Swaybar links, Brake lines, Shocks, and Full Spring Pack
      Fabtech 4 in. Performance Kit
      Includes: Coils, Rear AAL, Rear Shackle, Extended Sway Bar Links, and Shocks
      http://www.4wheelparts.com/PPT1906T5491.aspx
      Rock Krawler 4.5" Short Arm Flex Lift Kit
      Includes: Leafs, Coils, Double Adj LCA'a, Sway Bar Discos, and Rear Shims
      http://www.jackit.com/manufacturer/rockkrawler/jeep_xj_sa.htm#xj45sa
      Rock Krawler 4.5" X Factor Short Arm Kit
      Includes: Leafs, Coils, Double Adj LCA'a, Sway Bar Discos, Adj Trac Bar, and Shims
      http://www.tellico4x4.com/product_info.php/cPath/3601_3603_3608/products_id/24145
      Rock Krawler 4.5" X Factor Plus Long Arm Kit
      Includes: Leafs, Coils, High Adj LCA's, Long Arm Brackets, UTA, Adj Track Bar, Trac Bar Relcoation Bracket, Break Lines, Sway Bar Discos, and Rear U Bolts
      http://www.tellico4x4.com/product_info.php/cPath/3601_3603_3608/products_id/24146
      5-5.5 Inch Lift Options
      RE6200 XJ 5.5" Extreme Duty lift
      Tire Clearance: 33x12.50
      Includes: Coils, Full Spring Pack, Track Bar, LCA, Bumpstops, RE Gen2 Disconnects, and Break Lines
      http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=111
      RE6300 5.5" XJLA Extreme Duty
      Includes: Coils, Full Spring Pack, Shocks, Track Bar, LCA, Bumpstops, RE Gen2 Disconnects, Break Lines, and Long Arm Conversion
      http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=388
      T&T Customs XJ 5.5" Y-Link Suspension System
      Includes: Coils, Full Spring Pack, Shocks, Track Bar, LCA, Belly Pan, Shock Mounts, Drop Pitman arm, Unibody Bracing System, Shackles, and Sway Bar Disconnects
      http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=681
      DPG 5" Suspension System
      http://dpgoffroad.com/xjtrailgunner.htm
      6-6.5 Inch Lift Options
      Rustys 6.5" XJ/MJ Long Travel Suspension Kit
      Tire Clearance: 34x12.50
      Includes: Coils, Full Spring Packs, Shocks, Trac Bar, JKS Sway Bar Disconnects, and Break Lines
      http://rustysoffroad.com/mm5/mercha...s&Product_Code=605LT&Category_Code=sus_xj_kit
      Rustys 6.5" XJ Spring Pack Kit
      Includes: Coils, Full Spring Pack, Trac Bar, UCA, LCA, Break Lines, JKS Sway Bar Disconnects, and Shocks
      http://rustysoffroad.com/mm5/mercha...ys&Product_Code=605K&Category_Code=sus_xj_kit
      Rough Country 6.5" Suspension Kit
      Includes: Coils, Full Spring Pack, UCA, LCA, TC Drop Kit, Track Bar, Sway Bar Disconnects, Pitman Arm, and Shocks
      http://www.roughcountry.com/jeep_xj_6.html
      Skyjacker 6 in. Rock Ready Kit
      Includes: Coils, Full Spring Pack, Pitman Arm, and Hydro Shocks
      http://www.4wheelparts.com/PDT54902.aspx
      Full Traction 6" Kit
      Includes: Coils, Full Spring Pack, Long Arms, Quick Disconnects, Track Bar, and LCA
      http://www.full-traction.com/detail.php?MODELID=4&MAKEID=1&TYPEID=1&PRODUCTID=98&NOTES=9,10
      Rock Krawler 6.5" X Factor Plus Long Arm
      http://www.tellico4x4.com/product_info.php/cPath/3601_3603_3608/products_id/24151
      8 Inch Lift Options
      Skyjacker 8" Rock Ready Kit
      Tire Clearance: 36
      Includes: U-bolts, Double Flex lower control arms, Front brake hoses, Rear brake hoses, Dropped pitman arm, New control arm mount brackets and frame, Rear sway bar end links, Rear shackles, Front bumpstop spacers, Rear bumpstop spacers, Flex series upper control arms, Front sway bar links, Front track bar with steering stabilizer, Rear leaf springs, and Dana 30 cradle and brackets
      http://www.4wheelerssupply.com/cata...Sized&osCsid=1db1ec9436c3063021cc1596c1c189fc
      Rock Krawler 8" X Factor Plus Long Arm
      Tire Clearance: 36
      http://www.tellico4x4.com/product_info.php/cPath/3601_3603_3608/products_id/24152
      Rock Krawler Super 8.0" Plus with Rear Coil Over Conversion
      Tire Clearance: 36
      Includes: Double Adj LCA'a, Long Arm Brackets, UTA, Torque Arm Bracket, Adj Trac Bar, Trac Bar Relocation Bracket, Rear UCA, Rear 4 Link Mounting Cable, Coil Over Mounting Brackets, Break Lines, Rear Shocks, and Front Quick Discos
      http://www.tellico4x4.com/product_info.php/cPath/3601_3603_3608/products_id/24087
      Rustys 8" XJ Long Travel Suspension Kit
      Tire Clearance: 36
      Includes: Leafs, Coils, Shackles, Shocks, Drop Pitman Arm, Trac Bar, JKS Discos, and Front ans Rear Break Lines
      http://rustysoffroad.com/mm5/mercha...s&Product_Code=800LT&Category_Code=sus_xj_kit
      Thanks For Reading and I hope this Helps
      -Kyle
    1. · Premium Member
      Joined
      If you're on a budget I'd consider this along with some bastard pack leaf's and V8 ZJ coils
      Jeep XJ Suspension Lift
      I just bought this and am pretty happy, all considering. It's a great starter lift.
    1. · Registered
      Joined
    1. · Registered
      Joined
      ok! thanks a lot guys, this really helped, and durt, when you said the leaf springs were stiff, you mean that the back wasn't as high as the front? and what did you mean by the shackle lift kit? because thats not an option on the link i gave you, so i dont know what lift you're talking about. I'll post some pictures in a few days of my jeep as it is right now just so you guys can get a good look at it haha
      they were brand new so they were stiff, so the back sat a little higher.
      rubicon express is a good company, but they dont offer the shackle budget boost. this kit will be of similar quality but easier to install IMO. and quadratec will kill you on the shipping. rough country will give a 10% discount to jeepforum members, call in and ask to talk to jeff.
      rough country lift here
      dont mind it saying 1.5" the shackles give you 2" of lift, and the coil spacers measure out to the same 1 3/4" as the rubicon express spacers
    1. · Registered
      Joined
      COMPLETE LIST OF XJ LIFTS OUT THERE W/ LINKS AND ROUGH PRICING!--- Hey I know you guys have a somewhat similar thread but this is to complement that. I don't have pictures to go along with it but I am sure this is about 99% of the kits out there.
      Listed first by lift size then by price.
      The Baby Lifts (0-2.9")
      IRONMAN SUSPENSION
      http://www.ironman4x4.com/html/jeep/20.html
      1.76"-1100$ (I can only find one site that has their kit listed... it seems ridiculously high to me?) This Kit Includes: 4 Foam Cell Shocks, Full Leaf Springs, Coil Springs, Ubolts and Hardware.
      OLD MAN EMU
      http://www.4x4groupbuy.com/store/xj-old-man-emu-lift-2-p-2172.html
      2"- 839$- Old Man Emu does not have a home page and the ARB site is hard to navigate. This Kit Includes: 4 OME shocks, Coil Springs, Leaf Springs, and a set of JKS Quick Disconects. People who have Old Man Emu love them.
      SUPER LIFT
      http://www.superlift.com/Catalog.asp?P=K369&V=265
      2.5"- 510$- This kit lifts you 2.5" of lift and includes: Tubular Lower Control Arms, Add-A-Leaf, "Super-ride" Shocks, Hardware and a "Speed Sensor Calibrator." Superlift has been around for along time.
      RANCHO
      http://www.gorancho.com/suspension.php?make=Jeep&model=84_01_jeep_cherokee_xj#lift
      2.5"- 500$ This Kit Includes: Shocks, Front Coils, Control Arms, Add-A-Leafs, UBolts, Bushings and Hardware.
      BDS SUSPENSION
      http://bds-suspension.com/product?ma=7&mo=29&ty=38&yr=1984-2001
      2"- 431$ BDS offers this kit and 2 under it (1.75" lift and .75" lift). This kit includes: Coil Springs, Add-A-Leaf, Shocks, and Hardware. BDS has a great reputation.
      SKY JACKER
      http://skyjacker.com/product.php?ProdID=26863
      2"- 390-360$- This kit only comes with shackles, shocks and spacers. Sky Jacker has a few different 2" kits, but all are almost the same.
      RUBICON EXPRESS
      http://www.rubiconexpress.com/Lift-...NOMY KIT&Manufacturer_PQ=Rubicon Express#tab5
      2"- 260$ Kit Includes: Shocks, Spacers, Add-A-Leafs and a Brake Line.
      ZONE OFFROAD
      http://zoneoffroad.com/product?ki=31&gr=-1
      2"- 251$ Kit Includes: Add-A-Leaf, Spacers, and Hardware. Not a bad kit for the price.
      ROUGH COUNTRY
      1.5" 250$ Kit comes with shackles, Spacers, shocks, and bolts
      FAT BOB'S GARAGE
      http://4x4.fatbobsgarage.com/jeep-c...mance-8000-series-shocks-1984-2001-p7510.aspx
      2"-190$ Fat Bob offers a few different budget lifts. This is his most expensive 2" and includes Shocks, Shackles, Spacers and Hardware.
      http://4x4.fatbobsgarage.com/jeep-c...adjustable-rear-shackles-1984-2001-p1984.aspx
      2"-80$ This is his cheapest. This kit includes Hardware, Front Spacers and Adjustable Shackles.
      TOMKEN MACHINE
      http://www.tomken.com/catalog.php?search=terms=&model=XJ&year=1999&cat=liftkits
      2" 178.96$ Kit comes with Spacers, Blocks, Ubolts, Shock Extensions and Brake Extensions.
      DAYSTAR
      www.daystarweb.com/productdetail.php?productID=354
      1.75"-150$ Kit Includes: Spacers and Shackles.
      TERRAFLEX
      http://www.teraflex.biz/xj-cherokee-2-inch-budget-boost.html
      2"-150$ Kit Includes: Spacers and Shackles.
      TRAIL MASTER
      http://www.trailmastersuspension.co...SHACKLE LIFT W/ GREASABLE SHACKLES&Active=Yes
      2"-120$ Kit Includes: Spacers and Shackles.
      RUSTY'S OFFROAD
      http://www.rustysoffroad.com/jeep-s...-xj-cherokee-budget-boost-spacer-shackle.html
      1.75"- 99$ Kit Includes: Spacers and Shackles. Rusty's also offers a budget kit with Add-A-Leafs.
      Pre-School Lifts! (3-3.9")
      TNT CUSTOMS
      http://www.tntcustoms.com/rock-tek/3.5/suspension_solution/Jeep_Cherokee_XJ.aspx
      3.5"-2,395$ Kit Includes: High Clearance Belly Pan, Bent Y-Link Arms, Leaf Springs, Drop Track Bar, Bump-Stops, Sway Bar Disconnect, Steel Braided Brake Lines, Pitman Arm. TNT is generally considered one of the best.
      SKY JACKER
      http://skyjacker.com/product.php?ProdID=26240
      3"- 1360$-600$. Sky Jacker offers a few different 3" kits. The link is to the most expensive kit which includes: Leaf Springs, Lower Control Arms, Front Coils, Track Bar Bracket, and Hardware.
      OLD MAN EMU
      3"- 894$ Kit Includes: Shocks, Leaf Springs, Coils, JKS Quick Disconects and Hardware.
      RUBICON EXPRESS
      http://www.rubiconexpress.com/Lift-...HORT ARM&Manufacturer_PQ=Rubicon Express#tab3
      3.5"- 760-450$ Rubbicon express offers 4 different 3.5" kits. Two of them are "superflex kits" and two are "super-ride kits". Most of the kits include: Coils, Lower Control Arms, Sway Bar Links, Brake Lines, and either Add-A-Leaf or Full Leaf Packs.
      TUFF COUNTRY
      http://www.tuffcountry.com/suspension-kit/jeep-1987-01-cherokee-lift-kits.html
      3.5"-740-530$ TuffCountry offers two kits for the XJ. The cheap one comes with blocks in the rear while the more expensive one comes with full leaf springs. Both kits include: Shocks, Coils, UBolts, Extended (or Adjustable) Lower Control Arms, Transfer Case Drop Kit, Track Bar Bracket and Hardware.
      WARRIOR PRODUCTS
      http://www.warriorproducts.com/cata.../suspension/xj-cherokee-suspension-lift-kits/
      3"-660$- This Kit Includes: Shackles, Shocks, Front Coils, Control Arms, Sway Bar Links, and Hardware.
      BDS
      3"- 577$- Kit Includes: Shocks, Coils, Transfer-Case Drop, Sway Bar Links, Track Bar Bracket, and Blocks.
      PRO COMP
      http://www.procompusa.com/prodDetail.aspx?partNo=EXPK3058B&catID=1&subCat=38&ptID=5491&plID=1808
      3"- 573$- Kit Includes: Coil Springs, Sway Bar Links, Lower Control Arms, Brake Lines, Add-A-Leafs, and Shocks.
      RUGGED RIDGE "ORV"
      http://www.ruggedridgeoffroad.com/jeep-cherokee-orv-lift-kits.php
      3"- 549$ Kit Includes: Shocks, Coils, Lower Control Arms, Track Bar Bracket, and Hardware.
      RUSTY'S OFFROAD
      http://www.rustysoffroad.com/jeep-s...its/rustys-xj-cherokee-3-spring-pack-kit.html
      3"- 438-265$ Rustys offers two 3" lifts, one of them (438$) comes with full leaf springs while the other (265$) comes with Add-A-Leaf. Both Kits Include: Front Coils, Shocks, UBolts, Rear Brake Extension and Hardware.
      FULL TRACTION
      3.5"- 529$ This Kit Includes: Control Arms, Add-A-Leafs, Front Coils, Sway Bar Quick Disconnects, UBolts and Hardware.
      REVTECH INDUSTRIES
      (I know it says comings soon but they are available on some offroad sites)
      http://www.revtek.com/jeepsusp.asp#570
      3"-425$ This Kit Includes: Shocks, Add-A-Leafs, Front Coils and Hardware.
      ROUGH COUNTRY
      http://www.roughcountry.com/jeep_xj_3x.html
      3"- 345-255$ Rough Country has two 3" kits. Both Kits Include: Add-A-Leafs, Sway Bar Brackets, Shocks, and Hardware. The more expensive kit also includes lower control Arms.
      ROCK KRAWLER
      http://www.rockkrawler.com/index.php?r_intro=no
      (You have to navigate to the XJ section... It won't let me direct link.)
      3.0"- 380$ This Kit ONLY Includes: Front Springs and Rear Shackles.
      IRON ROCK OFFROAD
      http://www.ironrockoffroad.com/Merc...e=IROR&Product_Code=IR-X3LK&Category_Code=XLK
      3"- 340$ Kit Includes: Front Coils, Add-A-Leaf With Clamps, Shocks, Transfer Case Drop, Sway Bar Links, Rear Brake Extension and Hardware.
      ZONE OFFROAD
      http://zoneoffroad.com/product?ki=34&gr=-1
      3"- 291$ Kit Includes: Shocks, UBolts, Add-A-Leafs and Hardware.
      FAT BOB'S GARAGE
      http://4x4.fatbobsgarage.com/jeep-c...nce-8000-series-shocks-1984---2001-p7568.aspx
      3"-240$- Fat Bob's offers a bunch of different budget options for lifting your XJ. This is his most expensive. This Kit Includes: coil springs, add-a-leaf springs, shocks and a track bar bracket.
      http://4x4.fatbobsgarage.com/jeep-cherokee-xj-3-lift-kit-4wd2wd-1984-2001-p3833.aspx
      3"-90$ This is his cheapest. This kit has front spacers, hardware and a rear add-a-leaf.
      ROCKY ROAD
      http://www.rocky-road.com/xjbudget.html
      3"-149$ This Kit Includes: Blocks, Shackles, Bar Pin Relocators and Coil Spacers. For a little extra, you can also get a set of shocks.
      The Average Lifts (4.0-5.9")
      ROCK KRAWLER
      (Rock Krawler will not let me direct link on their site. You will have to navigate to the XJ section.)
      4.5" 3000-1050$ Rock Krawler offers 4 different 4.5" Kits. They range from the most expensive (Rear Coil Conversion, Long Arms all the way around) to a short arm kit using your stock upper control arms. Their stuff is very high quality but very expensive.
      SYNERGY SUSPENSION
      http://synergysuspension.com/Synerg...avel-Front-Rear-Kit-4-Link-Front-p-25694.html
      5.5"-2980$- I had to add the parts to make this a complete kit resulting in the elevated price. Just the arms is 1500$. This Kit (with the Springs/brake lines) Includes: Front and Rear Coil Springs, Complete Front and Rear Long Arms w/ Brackets, A Drop Pitman Arm, Track Bar and Hardware.
      TNT CUSTOMS
      http://www.tntcustoms.com/Rock-Tek/4.5Suspension_Solution/Jeep_Cherokee_XJ.aspx
      5.5"- 2599$ TNT is arguably one of the best. They have two kits in this category. One is 5.5", the other is 4.5". Both Kits Include: Belly Pan and Transfer-Case Skid Plate, Y-Link Long Arms, Leaf Springs, Track Bar and Bracket, Braided Brake Lines, Bumpstops, Quick Disconnects, Pitman Arm and Hardware.
      http://www.tntcustoms.com/Rock-Tek/4.5_Suspension_Solution/Jeep_Cherokee_XJ.aspx
      4.5"- 2,550$ Same as Above Just Smaller :D
      SKY JACKER
      http://skyjacker.com/product.php?ProdID=26269
      4.5"- 2160$ SkyJacker has like 7 different 4.5" lifts. This is the most expensive. The Kit Includes: Full Leaf Packs, Brake Lines, Shackles, Steering Stabilizer, Front Coils, Sway Bar Links, Pitman Arm, Control Arms (With mounting brackets), UBolts, Shocks and Hardware.
      CLAYTON OFFROAD
      http://claytonoffroad.com/product_info.php/cPath/18_66/products_id/113
      4.5"- 2100$ Clayton kits get great reviews. I don't think I have ever heard a complaint about them. This Kit Includes: Long Arms, Crossmember, Adjustable Trackbar, Adjustable Control Arms, Shims, Spring Retainers, Sway Bar Disconnects, Coils, Stainless Brake Lines, Ubolts and Hardware.
      RUBICON EXPRESS
      http://www.rubiconexpress.com/Lift-...ks.aspx?t_c=1&t_s=38&t_pt=3533&t_pn=R/ERE6300
      5.5"- 2050$ This is their Long Arm Kit. This Kit Includes: Front Coils, Long Arms, 3-Piece CrossMember, Full Leafs, Brake Lines, Sway Bar Disconnects, Shackles, Track Bar/Bracket, UBolts and Hardware.
      http://www.rubiconexpress.com/Lift-...ks.aspx?t_c=1&t_s=38&t_pt=3533&t_pn=R/ERE6200
      5.5"-1500$ This is their standard kit. This Kit Includes: Sway Bar Disconnects, Coil Springs, Bump-Stops, Leaf Springs, Brake Lines, Adjustable Trackbar w/Bracket, Shackles, Control Arms and Hardware.
      http://www.rubiconexpress.com/Lift-...ks.aspx?t_c=1&t_s=38&t_pt=3533&t_pn=R/ERE6111
      4.5"- 935$ They have two 4.5 Inch kits. I am only going to link one. This is the cheapest of the two. This Kit Includes: Add-A-Leafs, Control Arms, Adjustable Track Bar, Sway Bar Disconnects, Brake Lines, Ubolts and Hardware.
      BDS
      4.5"-1740$ This Kit Includes: 4 Short Control Arms, Full Leaf Packs, Coils, Shocks, Shackle, Track Bar, Swar Bar Links, Brake Lines and Hardware.
      IRON ROCK OFFROAD
      http://www.ironrockoffroad.com/Merc...=IROR&Product_Code=IR-X5CPK&Category_Code=XLK
      5.5"-1400$- This Kit Includes: Radial Long Arms, 3-Piece CrossMember, Full Leaf Springs, Front Coils, Shocks, Sway Bar Links, Track Bar w/Bracket, Brake Lines and Hardware.
      http://www.ironrockoffroad.com/Merc...=IROR&Product_Code=IR-X4CPK&Category_Code=XLK
      4"- 1050$- This Kit is the same as above but has Add-A-Leafs instead of full packs. It is also an inch and a half shorter :D
      http://www.ironrockoffroad.com/Merc...e=IROR&Product_Code=IR-X4LK&Category_Code=XLK
      4"- 450$- This Kit includes: Add-A-Leafs, Front Coils, Shocks, Transfer Case Drop Kit, Sway Bar Links, Brake Lines and Hardware.
      SUPER LIFT
      http://www.superlift.com/Catalog.asp?P=K788&V=263
      4"- 1300$ This is their "Rock Runner" Kit. This Kit Includes: "Swivel" Control Arms, Adjustable Track Bar, Front Coils, Full Leafs, Transfer Case Drop, Sway Bar Links, Shocks, Ubolts and Hardware.
      http://www.superlift.com/Catalog.asp?P=K787&V=263
      4"-1020$- This is their "Standard" Kit. This Kit Includes: Control Arms, Adjustable Track Bar, Front Coils, Full Leafs, Transfer Case Drop, Sway Bar Links, Shocks, Ubolts and Hardware.
      ROUGH COUNRTY
      http://www.roughcountry.com/jeep_xj_4xla.html
      4.5"- 1300$- Rough Country has a few different 4.5" kits. This is the Long Arm Kit. This Kit Includes: Long Arms, Front Springs, CrossMember, Drop Pitman Arm, Sway Bar Disconnects, Transfer Case Skid Plate, Adjustable Track Bar, Shocks, Ubolts and Hardware.
      http://www.roughcountry.com/jeep_xj_4x.html
      4.5"- 830$ This is their "X-series" Kit. This Kit Includes: Adjustable Short Control Arms, Front Coils, Transfer Case Drop Kit, Sway Bar Disconnects, Adjustable Track Bar, Brake Lines and Hardware.
      CURRIE ENTERPRISES
      http://currieenterprises2.reachlocal.net/cestore/product.aspx?id=3504
      4.5"- 1280$ Curie Has Been A Name In Jeeps Forever. I believe their lift kits are rather new. They have them for all different axle types but they are all pretty much the same. This Kit Includes: Coil Springs, Track Bar, Control Arms (With Johnny Joints), Full Leafs, Bushings, Bump Stops, Ubolts and Hardware.
      TOMKEN MACHINE
      4"- 971.20$- This kit comes with Rear leafs with bushings, Front coils, Sway bar mounts, Front Bump stops, Rear Bump stops, 1" trans case drop, Brake line ext, Axle shims, Lower adj control arms, Upper adj control arms, and U-bolts.. Tomken has been around for along time and recently re-vamped their products.
      FABTECH
      http://www.fabtechmotorsports.com/products/cart.php?m=product_detail&p=69&display=JEEP
      4"- 970$ This Kit Includes: Add-A-Leafs, Coil Springs, Shocks, Control Arms, Sway Bar Links and Hardware.
      RUSTY'S OFFROAD
      http://www.rustysoffroad.com/jeep-s...s/rustys-xj-cherokee-4-5-spring-pack-kit.html
      4.5"- 670$- This Kit Includes: Full Leaf Springs, Front Coils, Control Arms, Adjustable Track Bar, Shocks, UBolts and Hardware.
      http://www.rustysoffroad.com/jeep-s...ts/rustys-xj-cherokee-4-5-add-a-leaf-kit.html
      4.5"-590$ This kit is the same as above only it has Add-A-Leafs instead of Full Packs.
      ZONE OFFROAD
      http://zoneoffroad.com/product?ki=35&gr=-1
      4.5"- 495$- This Kit Includes: Control Arms, Shocks, Add-A-Leafs, Sway Bar Links, Brake Line Relocation Brackets, UBolts and Hardware.
      TRAIL MASTER
      http://www.trailmastersuspension.co...Part_Number=J4720SSV&Title=JEEP CHEROKEE XJ 4
      4"- $? (Can't find this kit anyway without the "Call For Pricing") This Kit Includes: Full Leaf Springs, Coil Springs, All Four Controll Arms (Short), Shocks, TrackBar, Brake Lines, Sway Bar Links, UBolts and Hardware.
      Trail Master Does offer a kit similar to the Zone kit but without shocks for 500 bucks.
      The Manly Lifts (6.0-7.9")
      CLAYTON OFFROAD
      http://claytonoffroad.com/product_i...d/107?osCsid=b58aa693968d7bb878069bd4ae8f9eab
      6.5"- 3550$- This Kit Includes: 8 Fully Adjustable Long Control Arms, Rear Coil Conversion, Stainless Brake Lines, Skid Plate, Adjustable Track Bar, Front and Rear Coils, Quick Disconnects, Rear Axle Bracket, Axle Truss and Hardware.
      ** Requires Welding
      http://claytonoffroad.com/product_info.php/cPath/18_66/products_id/329
      6.5"-2350$- This Kit Includes:3 Link Long Arm Setup, Full Leaf Springs, Spring Retainers, Coil Springs, Stainless Brake Lines, Adjustable Track Bar, JKS Quick Disconnects and Hardware.
      ROCK KRAWLER
      (I cannot direct link on RKs website so you will have to navigate to the XJ Section)
      6.5"-3180$- This Kit Includes: 8 Adjustable Control Long Arms, Rear Coil Conversion, Custom Brackets, Adjustable Track Bar, Front Coil Springs, Brake Lines, Quick Disconects and Hardware.
      ** REQUIRES: Welding, TJ 2" Rear Coil Spring, New Exhaust System
      6.5"- 1900$- Cheaper Kit that Includes: Add-A-Leafs, Front Long Arms and Brackets, Adjustable Boomerang Shackles, Front Coils, Brake Lines, Adjustable Track bar and Hardware.
      BDS
      http://bds-suspension.com/product?ma=7&mo=29&ty=38&yr=1987-2001&kid=455H
      6.5"- 2540$- This Kit Includes: 4 Link Front Long Arms and Custom Crossmember, Front Coils, Shocks, Rear Leaf Springs, Adjustable Track bar, Brake Lines, Quick Disconnects, Shackles and Hardware.
      SKY JACKER
      http://skyjacker.com/product.php?ProdID=26284
      6"- 2310$- SkyJacker has 3 different 6" lift kits. They are all almost the same so I am only going to link one. This Kit Includes: Radius Long Arm Setup w/ Mounting Brackets, Front Coils, Leaf Springs, Shackles, Sway Bar Links,Shocks, Brake Lines, Track Bar and Hardware.
      TOMKEN MACHINE
      6"-2126$- Kit Includes: 4 Link Long Arms, Axle shims, Front bump stops, Rear bump stops, Front/Rear brake lines, Set of 4 U-bolts, Upper controll arm mounts and brace, Lower controll arm trany mount, Drop Pitman, Front 6" coils, Rear 6" Leaf sprins ( bushings included)
      FULL TRACTION
      6"-1795$- This Kit Includes: 4 Link Long Arms w/Brackets, Shackles, Leaf Springs, Coil Springs, Quick Disconnects, Brake Lines, Adjustable Track Bar, Heim Joints and Hardware.
      RUSTY'S OFFROAD
      http://www.rustysoffroad.com/jeep-s...s/rustys-xj-cherokee-6-5-long-travel-kit.html
      6.5"-1740$- This Kit Includes: Radius Long Arm System (Two Upper and Two Lower), Cross Member, Shocks, Coil Springs, Leaf Springs, Adjustable Track Bar, Drop Pitman Arm, Stainless Brake Lines, Shims and Hardware.
      http://www.rustysoffroad.com/jeep-s...s/rustys-xj-cherokee-6-5-spring-pack-kit.html
      6.5"-1100$- This is the Cheaper of their two 6.5" kits. This Kit Includes: 4 Short Control Arms, Coil Springs, Leaf Springs, Shocks, Adjustable Track Bar, Quick Disconnects, Stainless Brake Lines and Hardware.
      IRON ROCK OFFROAD
      http://www.ironrockoffroad.com/Merc...=IROR&Product_Code=IR-X6CPK&Category_Code=XLK
      6.5"-1450$- This is the kit I run and I love it! Sorry for the small piece of opinion but I had to throw it in there. This kit comes with: 3-Arm Radial Long Arms, Leaf Springs, Shackles, Sway Bar Links, Adjustable Track Bar, 3-Piece Crossmember, Shocks, Coil Springs, Hardware and Great Customer Service :D
      http://www.ironrockoffroad.com/Merc...=IROR&Product_Code=RC-696N2&Category_Code=XLK
      6.5"- 900$- This is their cheaper kit. This kit includes: Coil Springs, Leaf Springs, 4 Adjustable Short Control Arms, Shackles, Adjustable Track Bar, Quick Disconnects, Drop Pitman Arm, Shocks and Hardware.
      ROUGH COUNTRY
      http://www.roughcountry.com/jeep_xj_6xla.html
      6"- 1450$- This Kit Includes: Radial Long Arms, CrossMember, Leaf Springs, Coil Springs, Shackles, Brake Lines, Quick Disconnects, Adjustable Track Bar, Ubolts and Hardware.
      http://www.roughcountry.com/jeep_xj_6x.html
      6"-900$ This is the cheaper of their 6" lifts. This Kit Includes: Coil Springs, Leaf Springs, 4 Adjustable Short Control Arms, Shackles, Adjustable Track Bar, Quick Disconnects, Drop Pitman Arm, Shocks and Hardware.
      JEEP PARTS GUY
      http://jeeppartsguy.com/products/?view=product&product_id=64
      6.5"- 756$- This Kit is piece together from a few different brands. It Includes: Coil Springs, Upper and Lower Adjustable Control Arms, Transfer-Case Drop, Adjustable Track Bar, Pitman Arm, Brake Line Relocation Bracket, Leaf Springs, Shackles, Brake Line Relocation Bracket and Hardware.
      The "Compensation Lifts" (8.0" and up) ;)
      CLAYTON OFFROAD
      http://claytonoffroad.com/product_i...d/332?osCsid=6508c9277b5d37d38cd6e69ace2aa353
      8"- 3510$- This kit Includes: A 3 Link Front/4 Link Rear Long Arm Kit, 3 Piece Crossmember, HD Trackbar, 3-Link Bridge for D30 (Front), Rear Crossmember, Coil Springs (All 4), Drop Pitman Arm, Coil Retainers, Brake Lines, Quick Disconects and Hardware.
      http://claytonoffroad.com/product_info.php/cPath/18_66/products_id/330
      8"-2500$ This kit is the same as above but only the front. It is a 3-Link Long Arm Kit and includes Leaf Springs in the back.
      BDS
      http://bds-suspension.com/product?ma=7&mo=29&ty=38&yr=1987-2001&kid=478H
      8.5"-2824$ This kit includes: 4-Link Long Arms, CrossMember, Coil Spacers, Shocks, Spring Retainers, Leaf Springs, Brake Lines, Shackles, Lift Blocks, Sway Bar Disconnects, Bump Stop Extensions, Drop Pitman Arm and Hardware. This kit has great reviews.
      SKY JACKER
      http://skyjacker.com/product.php?ProdID=26302
      8"-2470$ SkyJacker has three 8" lift kits. There are small differences (both in price and equipment) This kit has: Radial Long Arms w/ Brackets, Coil Springs, Leaf Springs, Quick Disconnects, Shocks, Shackles, Brake Lines, Pitman Arm, Bump Stops and Hardware.
      TOMKEN MACHINE
      http://www.quadratec.com/products/76016_841.htm
      (I'm not sure why it's not listed on their site. They have pictures of it but it is not found in the catalog.)
      8"-2100$ This kit comes with Coil Springs, Leaf Springs, 4 Adjustable Control Arms, Brake Lines, Blocks and Hardware.
      RUSTY'S OFFROAD
      http://www.rustysoffroad.com/jeep-s...its/rustys-xj-cherokee-8-long-travel-kit.html
      8"- 1900$- This is Rusty's 8" kit. The kit includes: Radial Long Arms, 3 Piece Crossmember, Front Coils, Leaf Springs, Shocks, Shackles, Drop Pitman Arm, Extended Brake Lines, Adjustable Track Bar, Ubolts and Hardware.
      IRON ROCK OFFROAD
      http://www.ironrockoffroad.com/Merc...=IROR&Product_Code=IR-X8CPK&Category_Code=XLK
      8"-1550$- Kit Includes: 3 Link Radius Long Arms, 3 Piece SubFrame, Double Shear Track bar, Leaf Springs and Add-A-Leaf, Shocks, Ubolts and Hardware.
      BUILDER PARTS/LONG ARMS/ETC
      SERIOUS OFFROAD
      http://www.seriousoffroadproducts.c...Existing-4-7.5-Short-Arm-Lift?cPath=419_1621&
      750$- Made by Serious Offroad, this kit allows you to add long arms to your 4"-7.5" lift kit. This kit comes with Teraflex Joints, a beefy crossmember, and all the equipment needed to mount it.
      ROCK KRAWLER
      (You have to navigate to the XJ Section. It won't let me direct link)
      1500$- Rear Coil Conversion. This kit allows you to remove your rear Leaf Springs completely and have Long Arms all the way around. It comes with/They Sell Everything you need to put it on. Rock Krawler also sells a ton of other parts for the XJ like: "Bomb-Proof" Track Bar, Coils, Shocks, A Few Different Long Arm Upgrades/Kits etc.
      IRON ROCK OFFROAD
      http://www.ironrockoffroad.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=IROR&Category_Code=XSP
      $Varies- Iron Rock Offroad offers many different builder parts including: Shackles, Coils, Leaf Springs, Spacers, Bushings, Ubolts, Shims ETC.
      JKS MANUFACTURING
      http://store.jksmfg.com/merchant2/merchant.mvc?Screen=CTGY&Store_Code=JKS01&Category_Code=CherokeeXJ
      $Varies- JKS offers many cool and unique parts including: Quick Disconnects, Adjustable Bump-Stops, Adjustable Control Arms, Adjustable Coil Spacers, Shackles ETC.
      RUFF-STUFF
      http://www.ruffstuffspecialties.com/catalog/
      $Varies Ruff Stuff offers many pieces/kits that allow you to build your own 3-link or 4 link long arm kit. They also offer rod ends, shackles, shock brackets, ubolts and just about everything else you need to make your own kit.
      TERRAFLEX
      http://www.teraflex.biz/shop-by-vehicle/cherokee-xj-84-01
      $Varies- Terraflex has a ton of builder parts and a few lifts. Some of the stuff they sell include: Disk Brakes, "Boomerang" Shackles, Long Arms, Drive-Shafts Bushings, Control Arms, Leaf Springs, BumpStops, Blocks, Transfer Case Kits and tons of other stuff.
      TNT CUSTOMS
      http://www.tntcustoms.com/suspensionupgradeXJ.aspx
      $Varies- TNT offers a ton of builder parts/upgrade parts if you want to build your own suspension. This includes: Long Arms, Control Arms, Track bars, Shackles and a bunch of other stuff.
    1. · Registered
      Joined
      COMPLETE LIST OF XJ LIFT KITS OUT THERE W/ LINKS AND ROUGH PRICING!--- Hey guys... here is a list of lift setups for you new guys who are not sure about what lift kits are available or you older guys looking to upgrade. I tried to get links directly to the manufacturer as they usually have the best pictures/info. The prices are by no means set and if you shop around you should be able to find them cheaper. I hope this helps you gives you some new ideas about kits you did not know were out there. Enjoy!
      * Please PM me if I am missing any kits/link quits working. I have been trying to make a complete list for awhile so that is why I repost on several different forums.
      ** There are some kits available on websites that are no longer in production EX: Rubicon Express 7.5", Black Diamond Lifts etc. Those will not be in the list as I don't know how long they will be available. There are also alot of places that make hybrid kits pieced together from multiple companies).. I will try to get some of those on here as they are usually cheaper
      TOUGH DOG SUSPENSION
      http://www.toughdogdealer.com.au/xjcherokee.htm#suspension
      1.57"- 2060-1800$ This kit includes: Coil Springs, Leaf Springs, Transmission Spacer, Shocks, Bushings, Ubolts and Hardware. The price changes depending on what shocks you get (Nitro, Foam Cell, Adjustable)
      IRONMAN SUSPENSION
      1.76"-1100$ This Kit Includes: 4 Foam Cell Shocks, Full Leaf Springs, Coil Springs, Ubolts and Hardware.
      OLD MAN EMU
      SUPER LIFT
      RANCHO
      BDS SUSPENSION
      ROCK LIZARD FAB
      2.5"-400$ This kit includes:Four Leaf Spring Pack, Coils, Long AAL, Spring Isolators, Spring Clamps, Center Pins, and U-Bolts
      2"-300$ This kit includes: Coils, Long AAL, Leaf Spring Clamps, Center Pins, and U-Bolts
      SKY JACKER
      RUBICON EXPRESS
      ZONE OFFROAD
      ROUGH COUNTRY
      FAT BOB'S GARAGE
      TOMKEN MACHINE
      DAYSTAR
      TERRAFLEX
      TRAIL MASTER
      RUSTY'S OFFROAD
      TNT CUSTOMS
      SKY JACKER
      OLD MAN EMU
      JKS MFG
      http://jksmfg.com/i-9056832-cherokee-xj-comanche-mj-1984-2001-front-adjustable-coil-spacer-pro.html
      1.375-3.25"- 885$ Kit includes: This is an adjustable spacer lift/bump stop. You can go between 1.375 and 3.25" of lift by simply turning the dial. Also has a hydraulic bump stop. Comes with all hardware. Does not include anything to lift the rear.
      RUBICON EXPRESS
      TUFF COUNTRY
      WARRIOR PRODUCTS
      BDS SUSPENSION
      PRO COMP
      RUGGED RIDGE "ORV"
      FULL TRACTION
      ZONE OFFROAD
      http://zoneoffroad.com/product?ki=436&gr=-1
      3"-510$ Kit Includes: Full Leaf Springs, Shocks, Ubolts, Coil Springs and Hardware.
      RUSTY'S OFFROAD
      REVTECH INDUSTRIES
      ROUGH COUNTRY
      ROCK KRAWLER
      IRON ROCK OFFROAD
      FAT BOB'S GARAGE
      ROCKY ROAD
      ROCK KRAWLER
      SYNERGY SUSPENSION
      TNT CUSTOMS
      BDS SUSPENSION
      http://bds-suspension.com/product?ma=7&mo=29&ty=38&yr=1987-2001&kid=468H
      4.5"-2400$ This Kit Includes: 4-link Long Arms, New Cross Member, Shocks, Leaf Springs, Coils, Shackles, Track Bar, Sway bar Links, Brake Lines and Hardware.
      4.5"-1740$
      SKY JACKER
      4.5"- 2160$ SkyJacker has like 7 different 4.5" lifts. This is the most expensive. The Kit Includes: 4-link RADIUS Long Arms with separate mounting brackets, Full Leaf Packs, Brake Lines, Shackles, Steering Stabilizer, Front Coils, Sway Bar Links, Pitman Arm, UBolts, Shocks and Hardware.
      CLAYTON OFFROAD
      RUBICON EXPRESS
      TRAIL MASTER
      4"- 1450$ This Kit Includes: Full Leaf Springs, Coil Springs, All Four Controll Arms (Short), Shocks, TrackBar, Brake Lines, Sway Bar Links, UBolts and Hardware.
      Trail Master Does offer a kit similar to the Zone kit but without shocks and with AAL for 500 bucks.
      IRON ROCK OFFROAD
      SUPER LIFT
      ROUGH COUNTRY
      CURRIE ENTEPRISES
      TOMKEN MACHINE
      FAB TECH
      ZONE OFFROAD
      http://zoneoffroad.com/product?ki=439&gr=-1
      4.5"-749$ This Kit is the more expensive Zone kit. It Includes: Full Springs, Control Arms, Shocks, Ubolts, Coil Springs, Shackles, Sway Bar Links and Hardware.
      RUSTYS OFFROAD
      CLAYTON OFFROAD
      ** Requires Welding
      ROCK KRAWLER
      BDS SUSPENSION
      SKY JACKER
      TOMKEN MACHINE
      FROEHLICH SUSPENSION
      http://froehlichsuspension.3dcartstores.com/65-Kit-and-Kaboodle_p_20.html
      6.5"-1843$ Kit Includes: 3 Link Long arms (50$ more for 4-link), Drop Pitman Arm, Add-A-Leaf with Blocks/Shackles and Hardware. For some extra cash, you can add Full Leafs, Shocks, and a Beefed up Steering.
      FULL TRACTION
      RUSTY'S OFFROAD
      IRON ROCK OFFROAD
      ROUGH COUNTRY
      JEEP PARTS GUY
      CLAYTON OFFROAD
      BDS SUSPENSION
      SKY JACKER
      TOMKEN MACHINE
      RUSTY'S OFFROAD
      IRON ROCK OFFROAD
      SERIOUS OFFROAD
      SEXTON OFFROAD
      http://sextonoffroad.com/i-8181742-tubular-radius-arms.html
      745$ Made by Sexton Offroad, this kit allows you to change your stock short arms to a radius long arm system.
      ROCK KRAWLER
      IRON ROCK OFFROAD
      JKS MANUFACTURING
      $Varies-
      Froehlich has quite a few different long arm kits you can buy as well as a rear-coil conversion. He also sells his own custom bumpers and various builder parts.
      RUFF-STUFF
      TERRAFLEX
      TNT CUSTOMS
      EATON/DETROIT SPRING
      http://www.eatondetroitspring.com/
      $Varies- Eaton/Detroit Spring offers tons of different custom length/built coil springs/leaf springs and the parts you will need to get them attached. Great if you are going to build your own kit.
    1. · Registered
      Joined
      Good evening! Guys my xj needs new rear leafs bad. Here's what I'm thinking; I'd like about 2 inches of lift all around. Just brain storming. I want this to still be a practical daily driver.
      Here's my first idea(I think this is good):
      1. Crown 7" arch heavy duty leaf springs with adjustable shackles
      2. Bilstein 5100 front http://www.amazon.com/gp/aw/d/B01MU20KWP/ref=ox_sc_act_image_3?smid=A1S9YHSAOS3JWY&psc=1
      3. Bilstein 5100 rear
      http://www.ebay.com/itm/294407463144
      4. 2 inch lift coil spring not sure what brand
      Other idea:
      Buy the old man lift kit for 1200 bucks bc why not. It comes with everything. I would need to pull one leaf out which one though. Link:
      http://ok4wd.com/old-man-emu-2-suspension-system-for-1984-2001-jeep-cherokee-xj
      Another idea:
      The rough country 1.5 inch lift kit.
      http://www.roughcountry.com/jeep-su...20.html?find=1997-jeep-cherokee-xj-4wd-736034
      Buy coil springs to match.
      Use the crown leaf springs.
      Another thing, I'm thinking about getting black rock wheels 15x7 or i may just get 15x8 or 10 put some nice tires on there. The back spacing would be 3.75 inches. If I do that and put 31s on there should be good to go right? I think the stance would be wider too.
1 - 9 of 9 Posts
Forum Reviews
Be the first to review this product
Write a Review
Do you have experience with this item? Help our community members and share your knowledge.
Sign in to add review
Top
