Joined
Pretty sure LH studs were never used on D27 or D30 axles. This appears to have the "outside" mounted rotors used in the conversion. Do you know if these are indeed the late CJ rotors or something else? Your choice of studs will be dependent on that.
This is the common D30 hub disc brake wheel stud:
As far as the above reference to Kaiser-Willys, I NO LONGER PURCHASE ANYTHING from there. It is almost all Omix-ADA and most of that stuff is absolute chinese junk.
