JeepForum.com (https://www.jeepforum.com/forum/)
-   Jeep MK Compass & Patriot Forum (https://www.jeepforum.com/forum/f98/)
-   -   size of rear rotors (https://www.jeepforum.com/forum/f98/size-rear-rotors-1058337/)
howdy246 06-26-2010 08:53 AM
size of rear rotors
Any one know how to tell the difference in the size of the rear rotors? I went to buy some new ones and found out that they could be 11.89" or 10.313"?
Gramps 06-26-2010 09:20 AM
All of my data for 2007 - 2010 calls for 11.5 vented on the front and 10.3 solid on the rear.
howdy246 06-26-2010 10:33 AM
Thanks Gramps, I just did the front brakes and now want to do the rears, but the web site I'm ordering form has the two different sizes. I've checked several other web sites and everyone else lists just the 10.3" so I'll order those.
By the way great prices here. Discount Auto Parts Canada - Auto Parts Warehouse | Complete Struts | Hub Bearing Assembly | Brake Pads and Rotors | Starters and Alternators | Prime Choice Auto Parts . I wasn't sure of the quality of the parts but they seem pretty good. I used their parts for the front brakes. I got 67,000kms out of the original ones so I'll see how much I get out of theses ones.
Gramps 06-26-2010 10:47 AM
After doing my fronts I checked the prices on the rears...cheaper is a good thing! :thumbsup:
tfmr 07-02-2010 05:49 PM
in the 2.0 CRD patriot the rotors have the same size? can't find that info anywhere:mad:
Gramps 07-02-2010 07:45 PM
I checked the Jeep International and the UK brochure and although they did not give a specification they didn't show a difference between petrol and Diesel. I'll tr and check with merlinTec and see if he can help.
merlinTec 07-03-2010 11:37 AM
Choice are
Referred to as "16-inch" because they are designed to fit inside 16-inch or larger wheels. Actual front rotor diameter is 294 mm (11.5 in.). Actual rear rotor diameter is 302 mm (11.8 in.).
Referred to as "14-inch" because they are designed to fit inside 14-inch or larger wheels. Actual rotor diameter is 262 mm (10.3 in.).
If you post the last 9 of your vin I will look up the jeep part number and you may be able to cross reference but I am sure all CRD's are the larger rear discs.
Note: there is a TSB 05-001-09 for European market for front brake pads
Part number
68020494AB Pad, Front Brake, and 5105514AA Rotor
tfmr 07-04-2010 05:38 PM
thanks for the info! :thumbsup:
Since here we only have the 17" wheels version, the rotor sizes are 294mm in front and 302mm in the rear :)
about the TSB, i didnt know :( but i've the 2008 model and made the 15k km and the 30k km service (a month ago) and they (jeep) didn't say anything about "brake" problems... the pads/rotors still the ones that came stock and now the warranty is over (only 2 years):mad:
i asked about the size, because in big distance or hard braking, the jeep makes a "thunder" noise, and i thought it was due to pad/rotor getting hot...
since the warranty is over, what do you thing about changing the front rotors to perforated ones(same size), and new pads?:confused: only when they need to be replaced!
the last 9 of vin: 38D525393 :)
merlinTec 07-05-2010 03:09 PM
Hi
rear pads 68028671AA, rear rotor 04743999AA based on you vin. front part numbers same as I posted above. I can't comment on other disc as I only know dealer fitment. I will leave after market stuff to others to comment on.
Regards,
Merlin
ekkirus 07-21-2017 01:07 AM
Originally Posted by merlinTec (Post 9738368)
Hi
Regards,
Merlin
Hi merlinTec
Not sure is that thread still active but
Could you please let me know rotor sizes & Part number of my newly purchased 2012 Jeep Patriot 2.4L
I have 16" rear Wheels and Last 9 on my vin - XCD617585
I am located in US right now.
MrBill345 07-21-2017 01:48 PM
Try this: measure the circumference with a soft tape.
The circumference is Pi times the diameter or C = Pi * D
Solving for diameter: D = C / Pi
Which means a Circumference of 37.4" (948.8mm) means Diameter is 11.89" (302mm) and a Circumference of 32.4" (823.1mm) means Diameter of 10.313" (262mm). Hope this helps.
The time now is 05:35 AM.
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
