Help I got these codes C12c, P0171, and P2174 - JeepForum.com
post #1 of 3 Old 06-25-2019, 09:29 AM Thread Starter
Jen4brigo
Jen4brigo's Avatar
I need help understanding these codes and now the battery light came on and my steering wheel is very hard to turn. HELP....
Jen4brigo is offline
post #2 of 3 Old 07-20-2019, 05:26 AM
Bugsymalone666
2011 MK Compass
Do you mean C121C? if its this its 'torque request denied'
P0171 is a misfire/fueling problem - engine running lean
The P2174 OBD-II trouble code is one of number of possible codes that indicates that the Powertrain Control Module (PCM) has detected a malfunction in the operation of the Throttle Actuator Control System.
Looking at that lot a couple of things spring to mind, firstly whats the condition of the alternator drive belt/water pump, if the engine was running a bit hot might cause some of these problems. Its the fact you mention the steering is hard to turn, I think the power steering pump is related to the water pump, they will certainly be run by the same belt.
Could be a result of a problem with the engine being overheated and the engine throttling power back to save itself.
Is this a Petrol or Diesel By the way?
Get it checked by a garage ASAP.
"Watcha Doin?"
"Oh you know, Jeep things....."
Bugsymalone666 is offline
post #3 of 3 Old 07-20-2019, 06:34 AM
jtec
jtec's Avatar
2014 JK Wrangler
Might want to add model, year, eng, trans to profile makes looking for answers, know issues, TSB's, tips etc specific to your vehicle.
jtec is offline
