Help front brake issue - JeepForum.com
post #1 of 1 Old 09-28-2015, 04:22 AM Thread Starter
cwilliams469
1995 XJ Cherokee
I got a 07 patriot and I replaced the front brake passing bolted the pins and set caliper on rotor pryed the old worn pads off I also pryed old rattle clips as the new pads wouldn't fit with them in , so I opened brake reservoir, compressed the caliper piston, lined up the pads slid them in the open slots, and lubed the pins and bolted them down and reassembled each side and put tires on and the tires didn't move just thought the caliper needed to relax and it would be fine after a short drive, drove it around the block and there hanging up and can't get past 3 gear what did I do wrong?? Any ideas none of the calipers hung by the hose or seemed sticky
cwilliams469 is offline
brakes , front brakes , pads
