Correct coolant - JeepForum.com
post #1 of 4 Old 04-02-2019, 04:05 AM Thread Starter
welderman85
Correct coolant
I'm looking for the correct type of coolant I need for a 2014 patorit. It's a little low and u want to add but not sure what type I need. Thank you
welderman85 is offline
post #2 of 4 Old 04-05-2019, 10:09 AM
Beware
2007 MK Compass
This is the one I use.
15544804637192286015128562710382_1554480490061.jpg   15544805032803613868486975570433_1554480540822.jpg
Beware is offline
post #3 of 4 Old 04-06-2019, 02:37 PM Thread Starter
welderman85
Thank you by any chance is there a compatible type at say autozone
post #4 of 4 Old 04-06-2019, 06:29 PM
Beware
2007 MK Compass
It's a terrible idea to mix different types of coolants. You should just add distilled water for topping off.
The 2014 patriot is due for flushing in 2019. (Flush and replace engine coolant at 60 months, or 102,000 miles (170 000 km) whichever comes first.)
I do not know of any alternative.
You can get it off amazon under $30, including free shipping by searching: 'Genuine Mopar Fluid 68048953AB Antifreeze/Coolant - 1 Gallon Bottle'
Perhaps others here having experiences with different coolants might be able to help you?
ENGINE COOLANT
WARNING: Antifreeze is an ethylene glycol base coolant and is harmful if swallowed or inhaled. If swallowed, drink two glasses of water and induce vomiting. If inhaled, move to fresh air area. Seek medical attention immediately. Do not store in open or unmarked containers. Wash skin and clothing thoroughly after coming in contact with ethylene glycol. Keep out of reach of children. Dispose of glycol base coolant properly, contact your dealer or government agency for location of collection center in your area. Do not open a cooling system when the engine is at operating temperature or hot under pressure, personal injury can result. Avoid radiator cooling fan when engine compartment related service is performed, personal injury can result.
CAUTION: Use of Propylene Glycol based coolants is not recommended, as they provide less freeze protection and less boiling protection.
The cooling system is designed around the coolant. The coolant must accept heat from engine metal, in the cylinder head area near the exhaust valves and engine block. Then coolant carries the heat to the radiator where the tube/fin radiator can transfer the heat to the air.
The use of aluminum cylinder blocks, cylinder heads, and water pumps requires special corrosion protection. Mopar® Antifreeze/Coolant, 5 Year/100,000 Mile Formula (MS-9769), or the equivalent ethylene glycol base coolant with hybrid organic corrosion inhibitors (called HOAT, for Hybrid Organic Additive Technology) is recommended. This coolant offers the best engine cooling without corrosion when mixed with 50% Ethylene Glycol and 50% distilled water to obtain a freeze point of -37°C (-35°F). If it loses color or becomes contaminated, drain, flush, and replace with fresh properly mixed coolant solution.
The green coolant MUST NOT BE MIXED with the orange or magenta coolants. When replacing coolant the complete system flush must be performed before using the replacement coolant.
CAUTION: Mopar® Antifreeze/Coolant, 5 Year/100,000 Mile Formula (MS-9769) may not be mixed with any other type of antifreeze. Doing so will reduce the corrosion protection and may result in premature water pump seal failure. If non-HOAT coolant is introduced into the cooling system in an emergency, it should be replaced with the specified coolant as soon as possible.
Beware is offline
Mysterious Coolant Level Issue TeleBruce WJ Grand Cherokee Forum 14 01-22-2019 12:14 PM
Mishimoto R&D: 2012-2018 3.6L JK Coolant Filter Kit Mishimoto JK Wrangler Technical Forum 3 01-16-2019 02:32 PM
5.7L HEMI equipped WK2 complete coolant change? macmechanic WK2 Grand Cherokee Forum 2 10-31-2018 06:47 PM
Coolant Mystery. What to use? FireGuy1996 JK Wrangler Technical Forum 15 06-27-2018 08:32 AM
Losing Coolant, smelling coolant SaharaNC JK Wrangler Technical Forum 4 03-19-2018 09:31 AM
