Check Engine Light 2007 Jeep Compass - Page 2 - JeepForum.com
post #16 of 20 Old 03-30-2015, 12:51 AM
Hondatrix
Originally Posted by 07Compass
I've had some issues with my 2007 Jeep Compass check engine light. I keep getting P0139 code so I replaced the sensor before the cat. I reset the codes and the light came back on now. I've replaced both O2 sensors and put new spark plugs in it too. Now it's reading P0138 P0139 and P0420. I guess I'm going to have to replace the cat. I can get a universal deal for like $150 or a OEM magna for $350. The Jeep runs great the only reason I'm even doing all this if for state emissions test. Before I drop the $350 on a new catalytic convertor. I figured I'd check with you guys for so tips on maybe it being something a little cheaper. I'm could replace all 4 coil packs at $25 each, or the fuel pump $$$. All three codes list misfire and fuel pressure as one of the causes. Any thoughts?
Question is, does the car have an actual misfire? If yes, then it needs to be fixed as consumption, reliability and safety will suffer....if NOT, then put in a few CAT foolers to fool the ecu..
Hondatrix is offline
post #17 of 20 Old 05-16-2015, 07:38 AM
JBear73
Just a question. In my 09 Compass, The check engine light comes on only in warm weather. Basically anything over freezing, but goes off at freezing or lower. I used the self check on the car by turning on the key 3 times to get the codes without using a OBD. However, the system tells me there are no codes! Also now and then, when in Drive and stopped..say at a red light. The car has what feels like a rough idle..but the RPM is constant with no changes.
I have no other warning lights..Temp or otherwise.
Any Ideas? Suggestions?
JBear73 is offline
post #18 of 20 Old 05-19-2015, 07:37 AM
JeepCACares
JBear73,
I'd recommend getting a hold of a code reader considering the check engine light would likely produce fault codes.
A Jeep dealer can certainly help you with this if needed.
JeepCACares is offline
post #19 of 20 Old 05-19-2015, 07:28 PM
07Compass
Question is, does the car have an actual misfire? If yes, then it needs to be fixed as consumption, reliability and safety will suffer....if NOT, then put in a few CAT foolers to fool the ecu.. Hondatrix I used the spark plug non-foulers on the O2 senor after the cat, and that worked for long enough for me to pass a state emissions inspection. So I'm good until next year, because it still runs fine.
07Compass is offline
post #20 of 20 Old 09-05-2015, 05:47 AM
ComradeChaos
ComradeChaos's Avatar
... I used the spark plug non-foulers on the O2 senor after the cat, and that worked for long enough for me to pass a state emissions inspection....
What in the heck are those???
ComradeChaos is offline
cel , compass , mil , patriot
2007 Jeep Compass Windshield Replacement fourheels Jeep MK Compass & Patriot Forum 11 02-22-2016 06:04 PM
2007 jeep compass suspension 10MRC Jeep MK Compass & Patriot Forum 4 12-15-2009 10:55 PM
Hi, I bought a new 2007 Inferno Red Compass Limited 2 days ago, yes-NEW 2007- Beware Jeep MK Compass & Patriot Forum 5 04-20-2009 06:40 AM
Carr Light Wing for extra fog/driving lights on Jeep Compass ngsdlite2 Jeep MK Compass & Patriot Forum 4 03-31-2008 02:50 AM
Check Engine Light/Other Issues Mistyfate Jeep MK Compass & Patriot Forum 4 03-21-2008 07:52 PM
