buying used oem rims with TPMS sensors - JeepForum.com
 1Likes
  • 1 Post By yzjwk
post #1 of 6 Old 01-21-2020, 04:47 AM Thread Starter
NorthernStang
2012 MK Patriot
I intend to buy used Patriots OEM alloy wheels that have TPMS sensors for my winter tires. Assuming that the batteries are still good in the sensors, will they sync automatically my vehicule?
2012 Patriot North
NorthernStang is offline
post #2 of 6 Old 01-24-2020, 08:08 PM
yzjwk
yzjwk's Avatar
2005 WK
2012 Patriot North
I assume you have a patriot to fit the new patriot wheels to? Those rims won’t fit your Wj without using a hub conversion spacer and the tpms is a different frequency.
Otherwise, patriot to patriot , yes the tpms sensors should just work.. unless your patriot has the tpms system that displays the pressure values in the evic (not sure if that was an option on the patriot) in that case you’ll probably have to get the wheel addresses assigned/programmed.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #3 of 6 Old 01-25-2020, 07:05 AM Thread Starter
NorthernStang
2012 MK Patriot
Thanks for your reply yzjwk.
And yes I own a 2012 Patriot without the EVIC.
Thanks for pointing out to me the need to change my profile, I used to own a WJ, no wonder nobody was replying to me.
So I should be good assuming that the batteries are still good in the sensors.
Will this work also with any Patriot/Compass/Caliber oem wheels?
post #4 of 6 Old 01-25-2020, 01:26 PM
yzjwk
yzjwk's Avatar
2005 WK
So I should be good assuming thaxt the batteries are still good in the sensors.
Yes, with the basic tpms system, no programming should be required, but the new sensors will need to be trained by driving for ~10min at >20mph . You might need to drive a little further to get all 4 linked up. also, you might get a tpms warning light at first because all 4 tires are wrong.
It would take a little longer, but what I would do, is change and train 1 tire at a time. this way if 1 of the sensors happens to be dead, you’ll know right away which one it is.
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
post #5 of 6 Old 01-31-2020, 06:47 PM
DonBecker
2016 MK Patriot
'Same question for a 2016 Patriot
My New-to-me 2016 Patriot has Freedom II Off-Road Group & CVT. I also plan to pick-up a used set of wheels for my winter tires. 'Anything I should be aware-of or will any wheels off of a Patriot work and self-program as described above? Thanks! Don
DonBecker is offline
post #6 of 6 Old 02-04-2020, 08:51 AM
yzjwk
yzjwk's Avatar
2005 WK
Same answer as above . The only issues with self reprogramming are generally with the premium model TPMS that displays tire pressure in the evic.
DonBecker likes this.
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
