alternator issues? - JeepForum.com
post #1 of 4 Old 09-30-2018, 12:11 PM Thread Starter
mabaker14
2008 MK Patriot
alternator issues?
My 2008 Patriot shuts off when the heat or air conditioner is turned on. I was told it needs an new alternator. Doesn't shut off when wipers, lights etc are used. Does this make sense or should I be looking at other issues?
mabaker14 is offline
post #2 of 4 Old 07-10-2021, 06:09 PM
andrusfive
2015 MK Patriot
Air Conditioner causing engine to die.
Did you ever get this issue resolved? I have the same issue with a 2015 Patriot and haven't been able to trace it down to the offending component yet.
andrusfive is offline
post #3 of 4 Old 07-15-2021, 03:18 PM
andrusfive
2015 MK Patriot
In case anyone runs across this post, My mechanic found a loose ground wire in a bundle underneath the intake assembly. That was the cause of the A/C causing the engine to die.
post #4 of 4 Old 07-15-2021, 07:36 PM
Pine_Cat
Pine_Cat's Avatar
Thanks, it's great to know a good mechanic !
2017 JK
2016 MK- Murchison springs, ~1" BL, skinny 30s
2011 KK- H&R lift springs, OldManEmu shocks/struts, skinny 31s
2009 Sorento- H&R springs, ToyTec strut spacers, OldManEmu shocks/struts, 31s
2006 TJ budget LCG prerunner- see profile
2006 Trailblazer- EXT lift, Nth LJ 4.5" springs + Monroe rear coilovers, skinny 32s
1998 Durango- SuspMax & Roadmaster lifts, rear Truetrac, skinny 32s
Pine_Cat is offline
