ABS, 4WD!, ESC (Traction Control) lights - JeepForum.com
post #1 of 2 Old 01-09-2018, 05:30 PM Thread Starter
Irish_Jeep
Hello all. I have a 2010 Compass 4x4 with a the ABS, 4WD!, & ESC Traction Control dash lights on.
I believe it is because of the rear drivers side wheel speed/abs sensor. I pulled the rear wheel off, followed some wiring to the backside of the hub, and found a connector that was loose, or came loose in the process. A picture I found online is exactly what it looks like, but I have not found where it plugs into on the backside of the hub. I'm unable to post a picture of the connector because of a lack of posts.
I'm sure this is the root of my problem... Can anyone point me in the right direction, or post a picture or drawing of the assembly.
Much Thanks in advance!
Paul
Irish_Jeep is offline
post #2 of 2 Old 02-02-2018, 04:47 PM Thread Starter
Irish_Jeep
This problem was resolved by replacing the Left Rear Hub Assembly and the Sensor.
