2012 Compass Maniverter Replacement - JeepForum.com
post #1 of 5 Old 05-09-2021, 12:55 PM Thread Starter
mitchpag
2012 MK Compass
I seem to have a throttle / acceleration issue. Comes back with a downstream catalytic code.
Now I have a couple options:
1.Pay the money, replace the manifold / converter part with OEM.
2. Replace the maniverter with a aftermarket part - actually looking at some pieces from muffler express out of Ontario, any thoughts?
3. I heard of finding a way to straight pipe the deal and do something with the o2 sensors. Fixes the reading error, but the engine light stays on for eternity.
Has anyone came across this issue and found a solution that works for them?
mitchpag is offline
post #2 of 5 Old 05-11-2021, 07:57 AM
yzjwk
yzjwk's Avatar
2005 WK
A good shop should easily be able to determine if the cat is plugged or the O2ís are not working properly. Generally, just having a cat fail without plugging up wonít cause a performance issue. If it hasnít been done recently, Most people just replace both oxygen sensors first because they normally fail first. What was the code?
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #3 of 5 Old 05-15-2021, 04:43 PM Thread Starter
mitchpag
2012 MK Compass
I took it to a shop in the fall, and they said it was a cat issue, but I guess there's two of them on this guy. the code I got was a p0420 generic. Saying cat system effic below threshold on bank 1.
mitchpag is offline
post #4 of 5 Old 05-16-2021, 08:02 PM
yzjwk
yzjwk's Avatar
2005 WK
Did the shop look at the functionality of the O2 sensors and scope the cat to see if the plates/honeycomb structures are done or did they just look at the code?
You can pretty much eliminate that code and engine light using a spark plug non fouler but it wonít help you if the cat is actually plugged. I had p420 codes on 2 of my jeeps that were both resolved that way once I verified thereís was nothing wrong with the cat.
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
post #5 of 5 Old 05-19-2021, 11:27 PM Thread Starter
mitchpag
2012 MK Compass
I replaced the spark plugs, and cleared the codes. Pretty much solved the acceleration issue, which I guess was actually multiple misfires... That couldn't be good.
However the same p0420 code came back on, which now I'm thinking that the overuse of the bad spark plugs is actually causing the code. Drives fine now though which is a plus!
mitchpag is offline
