2010 Jeep Compass Blower Motor Resistor - JeepForum.com
post #1 of 2 Old 12-03-2014, 08:31 PM Thread Starter
JohnDingess
I have had problems for a while with the ac/heat in my car only working on full blast. When searching online for the cause and solution, I found that the most likely cause was that the blower motor resistor burned out. I was able to find some videos of older different jeep models where they replaced the resistor. I have been able to remove my glove box as these videos advised but I was unsure if I had found the right part. I attached a couple pics below, if anyone could verify that I am looking at the right part or has a video of a 2010 getting the resistor replaced that would be very helpful!
A view of the glove box
https://drive.google.com/file/d/0B9L...ew?usp=sharing
What I think is the blower motor
JohnDingess is offline
post #2 of 2 Old 12-04-2014, 02:13 PM
Redpine
2014 MK Patriot
Blower motor resistors are a common problem. See if this helps: https://www.jeepforum.com/forum/f98/l...istor-1208526/
On my old Caravan, it was actually cheaper to get the part at the dealer vs. aftermarket, so check that out.
Redpine is offline
2010 , a/c , blower motor , compass , jeep
