2009 Patriot P0300 - JeepForum.com
post #1 of 3 Old 09-11-2021, 12:40 PM Thread Starter
Tesadorn
2009 Patriot P0300
Looking for some thoughts here.. I have an 09 Patriot that throws a P0300 (only code thrown) when rpms rise above 2k or so... If I clear the code it seems fine for a few min OR rises above 2k rpms.... At that point the ECU seems to shut off the injector pulse... to at LEAST cylinder 1 (my crappy Autel scan tool for some reason ONLY shows cylinder 1 pulses) Before I dig in has anyone had this same problem? I know coils, plugs first then compression test.. no smoke out back, oil is fine... Thoughts>?
Thanks in advance!
Dan
Tesadorn is offline
post #2 of 3 Old 09-11-2021, 01:26 PM
jtec
jtec's Avatar
2014 JK Wrangler
I am not familiar with that scanner.
P0300 often has accompanying codes, If you can look and see if there is any helpful info in 'freeze frame'
YES simply put The system will disable the offending cylinder. WHY a multi cyl code and affecting only #1 IDK, my guess scanner ability.
Maybe a second opinion so to speak - with CEL on take advantage of FREE scans at most auto part stores. Did I mention FREE
P0300 - any recent work? If you scanner does not have live data - checking fuel pressure and plug condition.
Looking at data - ECT, MAP, fuel trims long and short, and pre cat o2 sensors.
jtec is offline
post #3 of 3 Old 09-12-2021, 09:44 PM Thread Starter
Tesadorn
Looks like it was the relay marked "main"..swapped it cleared codes and drove for 30 min...time will tell...
Tesadorn is offline
