LinkBack | Thread Tools |
'09 Patriot 2wd, issues to look for?
My sister just got an '09 Patriot for $500. The body's in good shape, although my brother noticed unloading it that the rear crossmember has some rust pinholes. It's also got an evap leak and ABS light.
It looks like I'll be the one doing most of the work on it, although my brother's a professional mechanic.
First off what parts am I looking at buying for the rear crossmember? Going in, I'm expecting to have to replace the crossmember, and upper and lower control arms on both side. The sway/stabilizer bar links also need to be replaced.
I haven't plugged in a code reader to check codes for the evap and ABS issues.
I drive a WJ(which needs it's own share of work), so a Patriot is totally out of my wheelhouse.
Project Thumper:
KD2QQF
Member of Fourth Coast Jeeps
Sponsored Links | |||
Originally Posted by Ravenbar
View Post
https://chrysler.oemdtc.com/457/fron...compasspatriot
Good luck
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
Third time typing this so I'll be brief.
Our brother has second thoughts about his "pin hole in subframe" call and took a second look and pronounced it good enough. He'll be the one doing the state inspection, so that's good enough.
I have seen they'res a TSB for rear subframe rust. I don't see how it's a lot of work to change. It's a 2wd(FWD) model, so no drivetrain in the rear. Honestly, I see it as a long weekend project, replacing the upper/lower control arms and sway bar links(assuming that getting the bolts out is impossible.)
Project Thumper:
KD2QQF
Originally Posted by yzjwk
View Post
My understanding is this is a huge problem on this chassis and a lot of work to change . You may be able to fight FCA and get it done if there is still a pending recall. This page will list the part numbers.
Good luck
Good luck
Project Thumper:
KD2QQF
Previous Thread
Next Thread
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Posting Rules | |
