Wiper fluid not spraying strongly - JeepForum.com
post #1 of 6 Old 05-09-2015, 11:59 AM Thread Starter
nyyfan213
When I pull the lever to spray wiper fluid on my windshield, it sprays normally for about a second or two, and then it dies down and only reaches the bottom of the windshield. Does anyone know what might be causing this? Thank you
nyyfan213 is offline
post #2 of 6 Old 05-09-2015, 01:22 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
I have to ask.
Is the tank full?
Is this while parked?
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #3 of 6 Old 05-09-2015, 01:52 PM Thread Starter
nyyfan213
Originally Posted by jwmbishop
I have to ask. Is the tank full? Is this while parked?
yes the tank is full and it happens when parked or when the car is on
post #4 of 6 Old 05-09-2015, 03:02 PM
ialex2005i
Completely random guess, but I would be on the hunt for a hole/crack somewhere in the line or a loose connection which could be allowing air in. First thing that came to mind is when drinking from a cracked straw, which is almost impossible.
ialex2005i is offline
post #5 of 6 Old 05-09-2015, 03:50 PM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Tank mounted pump I believe. If the rear has lost its prime that could grab some pressure once the check opens... Use the rear washer until no air and see what happens. If topless I'm not sure how to coax it into giving up the juice...
(evil snicker)
post #6 of 6 Old 11-19-2015, 09:34 AM
kwkouki
kwkouki's Avatar
dealt with this last weekend. behind the reservoir is the fuse/pump pickup that sends the fluid. it will develop a good layer of sludge. wipe/hose it off and reinstall......... voila!
kwkouki is offline
