Whoa! No way am I paying this!!! - JeepForum.com
post #1 of 7 Old 06-18-2019, 09:27 AM Thread Starter
BChamberlin
BChamberlin's Avatar
08 manual has been popping out of first. Looked it up online and there is a TSB but no recall. Took it to the dealer. They’ve had it 2 weeks and quoted me $4300 for a rebuild and $6800 for a replacement transmission. Screw then and screw Chrysler. I have no idea what to do now.
1994 Wrangler YJ
1999 Wrangler TJ [R.I.P.]
2008 Wrangler X
BChamberlin is offline
post #2 of 7 Old 06-18-2019, 10:01 AM
RubiconFreedom
RubiconFreedom's Avatar
2017 JK Wrangler
B&M racing sport shifter #45195: $501.95
Semi-Retired Sr. Mechanical Assembler & Sr. Quality Assurance Inspector for Aerospace Industry
RubiconFreedom is offline
post #3 of 7 Old 06-18-2019, 10:06 AM Thread Starter
BChamberlin
Which will help how? The synchros are bad!
1994 Wrangler YJ
2008 Wrangler X
post #4 of 7 Old 06-18-2019, 10:27 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
You can pick up a used one for $2000-2500 on car-part.com
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #5 of 7 Old 06-18-2019, 10:48 AM
222Doc
222Doc's Avatar
labor will be high on any 4x4 trans work auto or manual. see remans for 5kish. so that sounds about right at 100$ an hour. since it would bet includes a clutch? they are in it its just parts now.
222Doc is offline
post #6 of 7 Old 06-18-2019, 10:52 AM
waterdowg
waterdowg's Avatar
Just to compare prices you can get a Trans for $3500- $4000 from AutoZone. Plus you have the cost of clutch and anything else that has wear. If you can't do the job your self you I would say about $900 for labor. So anywhere for $5000 - $6000. So the dealer is not to far off. I'm sure if you shop around you may find cheaper. I would start with a local trans shop for a quote. What sucks is that is about 1/2 of what the Jeep is worth.
waterdowg is offline
post #7 of 7 Old 06-18-2019, 11:02 AM
RubiconFreedom
2017 JK Wrangler
Pardon me for not following through on the question. In our area and with past wranglers, we were looking at new or rebuilt transmissions coating roughly $1,800 I merely suggested that if a B&M shifter is not within the rebuild, you're going to have the same issue in the future.
