Who has replaced their ball joints and what did you go with? - Page 4 - JeepForum.com
post #46 of 50 Old 08-10-2010, 11:57 AM
Hellbound13
Originally Posted by crusty1007 View Post
If you were looking down at the top of the knuckle, the upper ball joint should be behind the lower.
The further you rotate the axle back (upper is now further back than the Lower) will cause its return to center to be slower & respond to input slower, it will also follow the cracks in the road less. The more straight up & down the knuckle is, the quicker it will respond to input & will follow cracks in the road more. Im pretty sure thats what John is saying.
If you have any questions about our ball joints, let me know!
Thean
[email protected]
805-783-2060 Ext. 200
So which is the way to go? It sounds like with more caster you don't follow the ruts but with less you have better steering. Am I correct?
Hellbound13 is offline
post #47 of 50 Old 08-10-2010, 12:03 PM
crusty1007
because of rotating mass & balancing you typically can't get away with less than stock.
I usually end up around approx. 4.5 - 6 degrees.
If you jumped from stock to say 6 degree's you may notice a difference in steering response/feel. Most of the time you also changed to a larger tire size so you don't notice the effects.
Click the sig for everything you need to build a JEEP... 805-706-0232
NEW PRODUCTS ADDED DAILY !!!
----> Click and download the new catalog!!!
crusty1007 is offline
post #48 of 50 Old 08-10-2010, 12:58 PM
RockyClymer
RockyClymer's Avatar
[QUOTE=crusty1007;9935725]because of rotating mass & balancing you typically can't get away with less than stock.
So, John Currie is incorrect in what he is saying? Or do you just have an honest different opinion?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #49 of 50 Old 08-10-2010, 02:31 PM
crusty1007
Stock JK is 4.5 Deg. not sure where the 6-8 deg is coming from.
post #50 of 50 Old 08-10-2010, 03:25 PM
crusty1007
Here's a Link to our Jeep Forum Vendor listing with the JK Ball Joints:
https://www.jeepforum.com/forum/f43/n...oints-1086577/
aftermarket , ball joint , failure , JK Wrangler , replacement , worn out ball joints , wrangler
Need new ball joints. Help! chickenhawk7 JK Wrangler Technical Forum 9 03-22-2010 04:49 PM
Axle u-joints & maybe ball joints. CityJeep90 YJ Wrangler Technical Forum 2 06-04-2006 05:23 PM
ball joints DVS TJ TJ Wrangler Technical Forum 3 04-01-2006 10:38 AM
Help with front end work... ball joints, u-joints kaffeene YJ Wrangler Technical Forum 5 04-27-2005 08:45 PM
Ball joints, can it be done by anyone? mde YJ Wrangler Technical Forum 2 09-12-2003 06:42 AM
