Where to get new battery terminals? Mine are a bit corroded. - JeepForum.com
post #1 of 31 Old 04-02-2014, 03:39 AM Thread Starter
jakesteel1
When I check sites for Jeep parts, could only find the entire cable/terminal apparatus for like $160?
jakesteel1 is offline
post #2 of 31 Old 04-02-2014, 05:30 AM
PhatBasturd
PhatBasturd's Avatar
2010 JK Wrangler
Dealership is the only place I could find them.
Sent from my over priced iPhone.
PhatBasturd is offline
post #3 of 31 Old 04-02-2014, 05:40 AM
mello
Quadratec extreme duty battery cable ends for 34.99 they are what you need. They are very heavy duty I bought them for mine. They have plenty of places to jolt on accessories and some big bolts for winch cable.
mello is offline
post #4 of 31 Old 04-02-2014, 07:06 AM
minutemaidjk
What's the best way to keep your terminals from corroding?
minutemaidjk is offline
post #5 of 31 Old 04-02-2014, 07:19 AM
tjkj2002
2002 KJ Liberty
Install a AGM battery.
tjkj2002 is offline
post #6 of 31 Old 04-02-2014, 07:22 AM
JBTJ
JBTJ's Avatar
X2 Ever since I installed mine, no more corrosion.
JBTJ is offline
post #7 of 31 Old 04-02-2014, 07:33 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
On a normal battery, use brass terminals to avoid corrosion They can be gotten at Walmart.
D3<!L!>3D
S8NNG8 is offline
post #8 of 31 Old 04-02-2014, 07:38 AM
ridesno4llfe
Or just get battery terminal protectors (felt rings that go around the studs) and spray the terminals with the corrosion protector. Both are available at any parts house. 10$ vs 200$ for an agm
Everytime I sell a jeep I say no more then a new one shows up in my driveway
ridesno4llfe is offline
post #9 of 31 Old 04-02-2014, 07:44 AM
ncb
ncb's Avatar
Did your battery have a crack in the case next to the terminal? Mine cracked and the terminal looked like that. The Quadratec terminals are nice.
ncb is offline
post #10 of 31 Old 04-02-2014, 07:50 AM
wilywillie
wilywillie's Avatar
I carry a battery brush (male and female steel bristles to clean the posts and connectors), and that one pictured looks like it could be cleaned up no problem. Soda water helps get where the brush won't.
and yeah, a new battery is the best cure for that:-)
I'm just here for the gasoline. --Max
wilywillie is offline
post #11 of 31 Old 04-02-2014, 08:10 AM
R3dRid3r
My dad coated them with Vaseline.
Never argue w/ a WWII Marine who ran a machine shop of about 100 machinists.
"You'll Shoot Your Eye Out"
R3dRid3r is offline
post #12 of 31 Old 04-02-2014, 09:02 AM
mello
The felt rings mentioned above are the best thing out there for preventing corrosion. I have a 2002 F-150 with a 5.4 that was the worst vehicle I have ever seen for corrosion. I tried every trick in the book including all the other ones mentioned in this thread and the only one that worked for me was the rings. I now have zero build up on my terminals ever since I put them on. I use them on all my vehicles with perfect results. I work on a real big fleet of vehicles from a passenger car to road tractors and we use them on everything. As far as cleaning off corrosion it is as simple is coca-cola.
mello is offline
post #13 of 31 Old 04-02-2014, 12:02 PM
14Sport
14Sport's Avatar
That's what I've always done. Works great.
14Sport is offline
post #14 of 31 Old 04-02-2014, 12:06 PM
Lenny7
2006 WK
Mine have always had corrosion, replaced them once and they kept corroding, but ever since I installed my winch and hooked it to the battery no corrosion. Coincidence or is there something to that?
Lenny7 is offline
post #15 of 31 Old 04-02-2014, 02:48 PM
ronjenx
ronjenx's Avatar
The coca-cola thing is for rust, (iron oxide), and then it's marginally effective.
Corrosion on the battery terminals needs mechanical removal and a water/baking soda wash.
The felt rings are a good thing to install on the battery terminals.
But corroded terminals indicates the top of the battery needs to be washed with a rag moistened with water/baking soda. Acid can build up on the top of the battery and actually make an electrical path between the terminals.
ronjenx is offline
