What's a good Reusable air filter that's not oil based? - JeepForum.com
 3Likes
post #1 of 19 Old 06-18-2019, 06:18 AM Thread Starter
vicker
2011 JK Wrangler
Looking at a reusable air filter and I see some get oiled and some don't. Might get it in a cold air intake or just using the factory housing. Looking to squeeze out a few extra mpg. What's everyone's opinion on it?
vicker is offline
post #2 of 19 Old 06-18-2019, 08:43 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Wasting your time. And really wasting your $ if you do a CAI.
The factory air box and filters are quite efficient. "Performance" air filters will just let more dirt and dust into the engine and give you zero benefits.
But, if you do go that route, avoid oiled filters like the plague. The oil messes with and clogs up the MAF sensor.
Kev M likes this.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 19 Old 06-18-2019, 09:27 AM Thread Starter
vicker
2011 JK Wrangler
Looking to avoid the filters with oil
vicker is offline
post #4 of 19 Old 06-18-2019, 12:04 PM
RubiconFreedom
2017 JK Wrangler
When oiling or recharging our K&N I would drop in the STP air filter (autozone) and run this for a few days while the K&N cures. We've had this STP filter for 2 years.
RubiconFreedom is offline
post #5 of 19 Old 06-18-2019, 12:15 PM
cranbiz
cranbiz's Avatar
Like another posted said, the stock setup is remarkably efficient. Putting on a CAI is a waste of time and money and will possibly cause damage to your engine.
Any filter that provides more airflow to the motor, by definition, has to filter particulates less.
You are not going to get any additional MPG with this mod. Match your tire size to the gear ration and drive like Miss Daisy and you will get decent mileage.
Kev M likes this.
06 KJ
12 JK, 2.5" Teraflex lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #6 of 19 Old 06-18-2019, 12:22 PM
222Doc
222Doc's Avatar
total waist of money. especially here, paper and replace as needed. mine its every 3k. MPG with that year auto will be best with stock size tire #1. That year auto needs all of its 3.73 gears to do it well on stock tires. so if say you put on 33s or worse yet 35s and now MPG is like a 70s pickup. The only fix is gears, you cant tune your way out it or add headers or anything else. if your stock your as good as it gets in a jeep. i mean that should get what at least 17mpg? heck even the latest ones dont do much better. our 12jk did 19 at best on stock 32. but it is a Rubi and they did get at least 1/2mpg less then the other that year if they came with 4.1 and auto. still not bad for a heep.
Most any gain with air intake will be the far end of the RPM range As well NONE of these systems even pull cold air, meaning air out side of the engine bay. So the claim of COLD air? yea not true. the 3.8 dont run all that well at its end RPM range. they just dont breath all that well at say 5+rpms. even if it did the system has room anyway. power falls after 5k do to being push rod and no VVT. no cold air will change that. might as well add magnets to fuel lines and other gimmicks that they sell.
222Doc is offline
post #7 of 19 Old 06-18-2019, 12:45 PM
RubiconFreedom
2017 JK Wrangler
For what it's worth, I've had this same K&N filter for 10 years installed on 3 different JK wranglers. The purchase price back then was $45.00 via the K&N site. Never had the desire to want a cold air intake, just a drop in lifetime filter. Using or reusing the same filter has saved us a few hundred dollars over those 10 years. The clue is not to over clean or over spray the filter with the recharging fluid and allow it to cure for at least 24 hours.. I tend to allow 1 week of curing and wipe off any excess spray from around the filter. It's never cause any issues with any of our vehicles. Furthermore, that's one less paper filter in our landfills unless someone has a tip on recycling these paper filters.
JK4Three likes this.
post #8 of 19 Old 06-18-2019, 02:28 PM Thread Starter
vicker
2011 JK Wrangler
I'm not really expecting a big performance boost out of the cold air intake. honestly I like the sound from The increased airflow, I like the way it looks and I like the idea of a rechargeable medium. although I rather not use the oil and I know they make dry reusable air filters.
vicker is offline
post #9 of 19 Old 06-18-2019, 09:18 PM
ronjenx
ronjenx's Avatar
True, but only on vehicles that have a MAF sensor.
2008 JKU Rubicon
42RLE Auto
ronjenx is offline
post #10 of 19 Old 09-27-2019, 11:13 AM
Douglas Wampler
1975 CJ5
I'm piggy backing on this post. I have a 75 CJ-5 304. Is the K&N worth the money? does it help performance? Looking for informed opinions, Please.
Douglas Wampler is offline
post #11 of 19 Old 09-27-2019, 02:36 PM
L2R
I tend to believe the idea that oil filter is messing with my (new to me) rubicon
Been looking for a paper filter that I could just put on and throw away the K&N oil filter.
Oddly, found this thread just now.
engine light has been going on and off.
Finally caught the code while the engine was hot. P0219 (barometric pressure sensor) or map sensor.
Haven't found whether there is more than one MAP sensor or ??? but it sounds just like what is being discussed here.
L2R is offline
post #12 of 19 Old 09-28-2019, 08:54 AM
JohnR1
I like how people ask a question on this site and everyone offers there opions and wealth of knowledge, or lack of.
The filter you will want to will be aFe dry type S. I recommend that you get a spare filer and plugged filter indicator, k&n make one, part#85-2445 as you really cant look at them at tell that they are now flowing as much as they can. use a outerwears wrap to keep big stuff out of them and it will also not let water get past it.
on my 08 unlimited which has a motech 5.3, I started to have problems with my MAF sensor and it was getting coated with the oil from the specte filters that Robbie was using, so I carried a couple spare MAF sensors and a can of contact cleaner with me. to those who say that a cold air intake doesn't work, purchase a aeroforce defender meter and install is and watch you air intake temp with it. your underhood temp is running around 180 degrees or more. with a proper CAI you should be running ambient.
JohnR1 is offline
post #13 of 19 Old 09-28-2019, 09:33 AM
Ross
I can't people still want cold air intakes on an off road vehicle.
01TJ33sWarn,ARBs F&R,bellyup,4.0,4.56s,5spd
99 XJ33sWinch,Electric locker up front,4.56s,4.0Auto
Ross is online now
post #14 of 19 Old 10-07-2019, 08:59 AM
tahoeJeep
To simply answer the OP's question, Amsoil carries high performance filters that are dry (use no oil). Ran one on my 5.7 Hemi TJ and it worked great!
Joel
'04 WJ 2.7CRD
'12 JK Rubicon Orange Crush
tahoeJeep is offline
post #15 of 19 Old 10-09-2019, 08:51 AM
cranbiz
cranbiz's Avatar
Do what you suggest with a JK. The CAI's draw air in from the engine compartment, just like the stock filter. There is no way the intake air temp will be ambient. If you want a CAI in a JK, you need to run a snorkel. That is the only thing on the market that actually draws air in from the outside.
06 KJ
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
