What that outlet? - JeepForum.com
 2Likes
post #1 of 22 Old 01-05-2019, 10:15 AM Thread Starter
eloucha
eloucha's Avatar
What that outlet?
Since I have soft top and bought hard top I was installing my backup lights I found that mystery outlet can some one tell me for what is it ? And plz make fun of me thank u.
Sent from my iPhone using Tapatalk
eloucha is offline
post #2 of 22 Old 01-05-2019, 02:06 PM
mj23afs
Is it on the rear driver side corner? If so it is probably the power harness for the hard top washer fluid pump/wiper/defroster? Hard to tell what part of jeep Im looking at.
Sent from my SM-G950U using Tapatalk
mj23afs is offline
post #3 of 22 Old 01-05-2019, 03:22 PM Thread Starter
eloucha
eloucha's Avatar
Itís on passenger side I thought is for the hard top.
eloucha is offline
post #4 of 22 Old 01-05-2019, 03:35 PM Thread Starter
eloucha
eloucha's Avatar
Outlet is under that plastic trim in corner
mj23afs likes this.
eloucha is offline
post #5 of 22 Old 01-05-2019, 03:47 PM
mj23afs
Hmm. Im not sure. Looks like yours is a bit newer then mine. I am assuming the wire zip tied to the tailgate strap is the one you ran? Maybe a rear camera or something installed by the previous owner? Im guessing aftermarket something as my harness plugs are all blad with red lock tabs. If it were me Id have to pull some carpet to figure it out just out of curiosity.
mj23afs is offline
post #6 of 22 Old 01-05-2019, 04:30 PM
ronjenx
ronjenx's Avatar
Connector for rear speaker/12v outlet?
2008 JKU Rubicon
42RLE Auto
ronjenx is offline
post #7 of 22 Old 01-05-2019, 04:37 PM
222Doc
222Doc's Avatar
I think you are right. I took all that stuff out, tossed it. That plug was for the 12v and the speaker on the passenger side and my hard top stuff was driver. if i recall.
222Doc is online now
post #8 of 22 Old 01-05-2019, 06:28 PM Thread Starter
eloucha
eloucha's Avatar
I am thinking the same is for subwoofer Bc is manufacture plug not after market. That my only thoughts
mj23afs likes this.
eloucha is offline
post #9 of 22 Old 01-06-2019, 11:10 AM
cranbiz
cranbiz's Avatar
The 12v accessory outlet is on that side and if older than 2014, the sub would be there too.
02 WJ Laredo, heavily optioned but stock
12 JK, 3.5" Teraflex/Franken lift, Bilstein 5100's, BFG KM3's 37x12.5/R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #10 of 22 Old 01-06-2019, 11:19 AM
jscherb
Factory subwoofer: http://connectors.dcctools.com/details.htm?id=219036
"Whether you think you can do something or you think you can't, you are right" - Henry Ford
jscherb is offline
post #11 of 22 Old 02-09-2019, 04:25 PM Thread Starter
eloucha
eloucha's Avatar
Do u know where I can get a plug for it Bc I trying to hook cigarettes lighter plug to it to hook my fridge mopar discontinued I look on their web page.
eloucha is offline
post #12 of 22 Old 02-11-2019, 01:43 PM
cranbiz
cranbiz's Avatar
This is the part number. 68225137AA
However, that is only the sub connections. There isn't 12V in those pins.
There should be another connecter back there with, I think 2 wires but a 3 pin plug. That will be the aux plug harness. Beware, I think 10A is it's max capacity.
What are you going to use the plug for? I'm guessing something like a fridge?
A fridge can draw anywhere from 3-10A, some will fuse the cord at 15A. If that's the case, I would seriously consider running a 10-12 GA wire from the battery and connect those to the outlet. That way, you know you have heavy enough wire.
In my JK, I installed my own 12V / dual USB plugs. I ran a 12GA wire direct to the outlets from the battery. It runs my fridge (3A max draw) used to run a 12V charger for my streamlight and could run USB accessories.
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #13 of 22 Old 02-11-2019, 03:51 PM Thread Starter
eloucha
eloucha's Avatar
u mean this plug sorry. I am dummy with electronics so there is outlet for this on or just I cured and solder to it ?yes backup-camera or fridge
eloucha is offline
post #14 of 22 Old 02-11-2019, 03:54 PM Thread Starter
eloucha
eloucha's Avatar
I agree for fridge I will run 12A wire straight to battery Bc I saw some one plug melt but I can use it for backup camera correct
eloucha is offline
post #15 of 22 Old 02-11-2019, 04:58 PM
cranbiz
cranbiz's Avatar
A backup camera uses miniscule amounts of power. So the factory cable will have more than enough capacity.
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
