Water leak - JeepForum.com
post #1 of 8 Old 05-30-2020, 09:09 AM Thread Starter
Sterns
Water leak
My 15 JKU is getting a lot of water on both driver and passenger sides after some heavy rains in the past 2 weeks, I removed the floor mats and the rug under them is totally soaked on both sides. I donít see any leaves in the grill by the windshield but I havenít tried removing the wipers and the grill. Is there a drain hole there that could be blocked? Not sure that even if this was the case, it would lead to water inside.
I also donít see any issues with the door seals, they look in good shape. The rug is soaked only on the floor bottom, not up the sides, so no clue where itís coming from. Are there any other sources of water that could lead to both sides getting water? Any help in ideas what to check would be appreciated.
Sterns is offline
post #2 of 8 Old 05-30-2020, 09:11 AM
Moezer
2015 JK Wrangler
Are u running a soft top? If so then check the seal on top of the windshield
Sent from my SM-N950W using Tapatalk
Moezer is offline
post #3 of 8 Old 05-30-2020, 12:21 PM
222Doc
222Doc's Avatar
There is a thread on JK leaks. Its a jeep thing with Jks. There are a lot of seals involved with Freedom top having panels. Even dealers are miffed at times. Remember T tops. had less seals, they leaked. There must be a few hundred post on this by now and the many places it may leak from. Its not in the cowl.
I wonder if mine leaked, i am sure it would have. Its only had a bikini top for 7 years. Its garaged if not on a trail. But we have been caught in Mountain pour downs and desert rain in it too. it can get real wet. i removed the carpet when this jeep was new. Still have it. Jeeps should not have carpet. metal floor are easy to wash out. For the first few years i ran just the freedom panels with no back top. That configuration many people do not know they can do. Makes a Hard bikini top. That is why there is those little flip down things on the panel. Files the gap where the rear top would be and those big plastic bolts tighten it all down. Those bolts should be over tightened when you HAVE the rear hard top on that can make it leak too. Hard trails here things like that get broke fast. we use the roll bar as sliders at times. so its had the soft bikini since. every jeep i have ever had leak in some way if it was real wet out. None ever had carpet though. so it mattered less.
222Doc is offline
post #4 of 8 Old 05-30-2020, 12:45 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Here's Jeep's Diag and Repair manual for soft and hard top leaks to help determine where it's coming from and how to fix it:
https://www.meyerdistributing.com/ma..._for_Leaks.pdf
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #5 of 8 Old 05-30-2020, 04:05 PM
JoonHoss
JoonHoss's Avatar
2011 JK Wrangler
I bet, if after it has rained a bit, you can open the door, you'll see water running down your A pillar. You'll also see a little trickle across the door sill right across the bottom of the plastic next to the door sill where it's running onto your carpet.
(Ask me how I know)
Hoss
Good judgement comes from experience; experience comes from bad judgement
JoonHoss is offline
post #6 of 8 Old 05-31-2020, 08:10 AM Thread Starter
Sterns
Originally Posted by Kruzin View Post
Here's Jeep's Diag and Repair manual for soft and hard top leaks to help determine where it's coming from and how to fix it...
Thanks that was very useful info.
Sterns is offline
post #7 of 8 Old 05-31-2020, 08:14 AM Thread Starter
Sterns
Itís a hard top, but could be from the top panels.
Sterns is offline
post #8 of 8 Old 05-31-2020, 08:10 PM
Prot
Prot's Avatar
2014 JK Wrangler
My 2007 hard top JKU never leaked
Twice on my 2014 JKU hard top I got in to find a single drop of water on the dashboard after an extremely hard rain. That’s all.
The idea that because it is a JK or JKU it will leak is preposterous.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
leak , water
