Want to know your gear ratio for sure? - Page 2 - JeepForum.com
 2Likes
post #16 of 32 Old 11-29-2012, 11:40 PM
riot1987
riot1987's Avatar
That axle seems almost useless in a wheelin rig.. Aint that a little high?
Build thread^^
riot1987 is offline
post #17 of 32 Old 11-29-2012, 11:44 PM
ronjenx
ronjenx's Avatar
What vehicle is it in?
ronjenx is online now
post #18 of 32 Old 11-29-2012, 11:48 PM
riot1987
riot1987's Avatar
It out of a mid 70's 1/2 ton chevy
Build thread^^
riot1987 is offline
post #19 of 32 Old 06-01-2014, 06:11 PM
cheroxy
Sorry to resurrect this old thread, but I did what it said on my 2003 TJ and got 7.25 rotations on drive shaft to the 2 rotations of my tire. I have 35" tires on 15" rims. Are these numbers for JK's only?
cheroxy is offline
post #20 of 32 Old 06-01-2014, 06:19 PM
cheroxy
Nevermind, a little more digging found it, I had both tires rotating instead of just one. It looks like i Have the 3.73 stock ratio.
cheroxy is offline
post #21 of 32 Old 06-01-2014, 06:28 PM
ronjenx
ronjenx's Avatar
Here is the condensed version:
Jack one front tire off the ground.
Put a chalk mark on the tire and the drive shaft.
Rotate the tire by hand 2 complete revolutions while counting the drive shaft turns. The number will be your gear ratio.
A little less than 3 and 1/4 turns will be 3.21 gears.
About 3 and 3/4 turns will be 3.73 gears.
A little over 4 turns will be 4.10 gears.
post #22 of 32 Old 06-03-2014, 09:27 AM
Airborne Lee
Airborne Lee's Avatar
Raised Jeep, turned wheel two times, had six beers, I must have 3.10 gears?
'16 JKU Rubicon, Tan, RR Front Bumper, 9500i, Atlas Rear w/Tire Carrier M416 Trailer
Airborne Lee is offline
post #23 of 32 Old 06-03-2014, 09:57 AM
ronjenx
ronjenx's Avatar
See what you get with just one beer.
Did your drive shaft turn a little less than 3 and 1/4 turns?
post #24 of 32 Old 06-04-2014, 02:59 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Raised one rear tire, rotated 2 times, got dizzy and fell down. Drank another beer, raised another tire (on the front this time), rotated two times (this time remembering to turn the TIRE duh), but the muffler didn't turn so lost track or what I was doing.
Drank another beer.
Drove to mechanic to show me how to do the simple check - forgetting to take jacks out. Thank the lord for steel jack wheels - rubber would not have lasted 6 miles.
Does this mean I have a CAI instead of a gear ratio?
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #25 of 32 Old 06-04-2014, 06:20 PM
1222
RIP John
1222's Avatar
Drank another beer.
No it means you should stick to iced tea instead.
(2011-2016)
1222 is offline
post #26 of 32 Old 02-20-2015, 08:22 PM
SlickJeeper
2010 JK Wrangler
i need help are 5:13 gears good for a 2010 wrangler on 35's or is that to low of a gear ratio?
SlickJeeper is offline
post #27 of 32 Old 02-20-2015, 08:41 PM
Maertz
Maertz's Avatar
2009 JK Wrangler
Na id do 5.38
Wishing I Wasn't Part Of The 'JK' Crowd...
Maertz is offline
post #28 of 32 Old 02-20-2015, 09:37 PM
1222
RIP John
1222's Avatar
5.13ís are the most popular gear choice for the JK with 35ís and auto. Some people go as low, high numerical, to 5.38ís and are very happy with that choice also. This is all for the 3.8 engine (2007-2011) which you have. For those that have the 3.6 (2012-2015) this does not apply.
It would help if you would fill in your profile so we can give better advice. For instance, we have no idea what transmission you have which will reflect just what gears to select.
(2011-2016)
1222 is offline
post #29 of 32 Old 12-29-2019, 06:39 PM
sprkeng
sprkeng's Avatar
2011 JK Wrangler
Originally Posted by MilitaryJK4455 View Post
Thanks ronjenx, for writing this out for us.
Finding Your Gear Ratio
Here is a procedure to get the axle ratio when it is not known. Build sheets (available from your dealer, or from the Jeep web site) will only tell you what the Jeep had from the factory. A used Jeep could have been re-geared.
If you want to know for sure, and remove all doubt, do this:
Chock the front tires, fore and aft.
Put the transmission in neutral.
Emergency brake off.
Jack the left rear tire off the ground.
Put a jack stand under the frame, just in case the jack fails (had to add this).
Put an index mark on the aft end of the drive shaft, visible from the left rear wheel.
Put an index mark on the left rear tire at the 6 o'clock position.
Rotate the left rear tire 2 complete revolutions while counting how many times the index mark on the drive shaft passes its original position.
That number will be your axle ratio.
Remove jack stand and lower jack.
Put transmission in gear or Park, apply emergency brake.
Remove chocks.
If you have limited slip, jack up both rear wheels and rotate one revolution, making sure both tires rotate equally.
If the drive shaft rotated almost 3 1/4 turns, you have 3.21
If the drive shaft rotated almost 3 3/4 turns, you have 3.73
If the drive shaft rotated a little over 4 turns, you have 4.10
If the drive shaft rotated a little under 5 turns, you have 4.88
If the drive shaft rotated a little over 5 turns, you have 5.13
Now go drink a beer and feel confident that you know your gear ratio without a doubt
This is very informative. Simple and to the point.
I purchased my 2011 JK Sport 2-door standard in 2012. I fortunately had the part number sticker on the front axle and the steel tag on the rear axle. My Jeep was built on 05-28-10 stamped with a Dana 30 3.21 front and Dana 44 3.73 rear.
I found this thread last night, so this morning I decided for giggles to try it out.
I counted just under 4 turns for the rear axle, so it does work.
2011 Wrangler JK Sport
All Standard Stock 6 Speed Transmission
2.5 lift new Bestop NK softop
sprkeng is offline
post #30 of 32 Old 12-29-2019, 07:27 PM
ronjenx
ronjenx's Avatar
It sounds like you are saying your JK has 3.21 in the front and 3.73 in the back. If that were so, you would not be able to drive in 4wd.
Do the same check for the front axle and you will see it has the same ratio as the rear.
2008 JKU Rubicon
42RLE Auto
confirmation , gear ratio , how to , JK Wrangler , wrangler
wanderer1951
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 07:58 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 07:40 AM
how to tell gear ratio by the ring gear YJscott2 YJ Wrangler Technical Forum 6 01-10-2010 08:30 PM
Gear Carriers for gear ratio swap bwiencek YJ Wrangler Technical Forum 1 05-04-2006 10:52 AM
Stock Gear Ratio - Speedometer Gear Moxley YJ Wrangler Technical Forum 2 06-06-2003 10:52 AM
