Upgrade alignment parts? - JeepForum.com
post #1 of 16 Old 06-28-2010, 02:32 PM Thread Starter
JK_Jeep
JK_Jeep's Avatar
I have a 2007 Rubicon 2 door.
No lift, stock wheels and tires, hey I live in the midwest LOL I should have never bought the Rubicon, but I did.
Anyhow, I bought a new set of Mud Terrains in July of 2009 and the fronts tires are trashed. Sears had a problem aligning it, something about the cam nut was bad?
The tires are all choppy, so before I buy another set I need to replace the steering compnents with some decent ones that will last.
I looked at the poly performance but I need a spacer just to use the stock wheel
I like the stock look.
What parts should I replace and what brand ?
IT'S A JEEP THING!
Originally Posted by sierraexplorer
Thanks, if it is that good than I'm sure that they can't sell it in California. Everything else is illegal in this state except the illegalsl
JK_Jeep is offline
post #2 of 16 Old 06-28-2010, 02:37 PM
juiceparn
juiceparn's Avatar
If your stock why is there a cam nut? This is usually something added when lifted to account for the lack of adjustable control arms. You sure you don't have a BB or something?
07 JK 4DR 3.5" Rubicon Express, C gussets, Front XHD stubby, winch, Taboo Customs rear bumper with tire carrier, Taboo Customs Rock sliders.
juiceparn is offline
post #3 of 16 Old 06-28-2010, 02:37 PM
McKBrew
McKBrew's Avatar
JK Wrangler
There isn't much to doing an alignment especially on a stock vehicle. Honestly I think the fault lies with Sears. There is a good write up floating around on how to do a basic alignment (It is really simple), you might try doing it yourself after getting new tires (or take it somewhere besides that Sears). I can't imagine anything being jacked up enough on a stock vehicle that would cause excessive tire wear unless a mistake was made somewhere. What specific components are you thinking of replacing?
McKBrew is offline
post #4 of 16 Old 06-28-2010, 02:56 PM Thread Starter
JK_Jeep
JK_Jeep's Avatar
Maybe that is what he suggested was the cam bolt.
I want to replace what parts are weak.
The tires were chopped up before I bought the new set and took them to sears, then sears installed the new set of tires and aligned it. I was hoping that would fix them, then 9 months later, they are getting chopped up again
IT'S A JEEP THING!
JK_Jeep is offline
post #5 of 16 Old 06-28-2010, 03:04 PM
juiceparn
juiceparn's Avatar
Then it sounds like the alignment was never done correctly. At stock height you should not need cam bolts unless something is messed up. Control arms would be the real fix if you actually do need cam bolts.
post #6 of 16 Old 06-28-2010, 03:09 PM Thread Starter
JK_Jeep
JK_Jeep's Avatar
from what I can find on the internet, they are "feathered" for the wear
When the wife gets home from work I will take pictures of the tires so we can see the wear
IT'S A JEEP THING!
JK_Jeep is offline
post #7 of 16 Old 06-28-2010, 03:23 PM
Imped
Imped's Avatar
On a stock height jeep, just make sure the toe is set correctly and you rotate the tires every 3k miles. If one or both hasn't been done, that's the problem. Camber and caster won't cause your problem.
And what does living in the midwest have to do with owning a rubi?
OlllllllO
IndyORV
Imped is offline
post #8 of 16 Old 06-28-2010, 03:29 PM Thread Starter
JK_Jeep
JK_Jeep's Avatar
Wouldn't lack of tire rotation show wear on front and rear?
I will admit, I have not rotated the tires, only because the first set I put on the Jeep I did rotate then it ruined the set from the back.
At this point the only tires messed up are the fronts, that is why I do not want to rotate
IT'S A JEEP THING!
JK_Jeep is offline
post #9 of 16 Old 06-28-2010, 03:31 PM
juiceparn
juiceparn's Avatar
[QUOTE=And what does living in the midwest have to do with owning a rubi?[/QUOTE]
YEAH! I don't have a RUBI but I wheel every chance I get and I bend and break stuff too!! We have it all mud, rocks, trails, malls............
post #10 of 16 Old 06-28-2010, 03:34 PM Thread Starter
JK_Jeep
JK_Jeep's Avatar
I know, but when I lived in SoCal, the lift was more applicable than here, at least for me
IT'S A JEEP THING!
JK_Jeep is offline
post #11 of 16 Old 06-28-2010, 03:38 PM
juiceparn
juiceparn's Avatar
Just playin' man!
post #12 of 16 Old 06-28-2010, 03:56 PM
Imped
Imped's Avatar
If your tires are "messed up" then rotate them to the other end! Rotating every 3k won't give the tire enough time to wear oddly and if you do a proper rotation, your tires should last for a very long time.....longer than if you don't rotate. Obviously something is wrong. Worn ball joints or a bent housing are causes of crappy camber, which could be your problem. Go to a good alignment shop to give you a readout on the front toe, caster, and camber and the rear toe and camber. If something is wrong on a stock height verhicle, then something is bent and/or the ball joints are badly worn.
OlllllllO
IndyORV
Imped is offline
post #13 of 16 Old 06-28-2010, 08:09 PM
yoda13
Force Wheeler
yoda13's Avatar
Unfortunately, both are issues that crop on on JKs more often than I like reading...
2007 White Jeep Wrangler X-auto, black freedom top, 15x8 Pro Comp Rock Crawlers, 33x12.5x15 BFG KM2s, Superchips Flashpaq, 2" OME Spring Lift, Bilsteins, Rusty's Adjustable front and rear trac-bar, JKS Quicker Disconnects, Rusty's adjustable lower control arms (front and rear), PolyPerformance adjustable upper control arms (front and rear), OEM Rubicon Rock Rails, Finishlinewest Stonehenge Series rear bumper, Smittybuilt winch, Body Armor Front High Clearance Bumper w/ KC Highlights mounted, Roadmaster towbar, Valley 2" receiver hitch, Skid Row Engine Transmission skid, sPod switching system, KC Highlights windshield mounted lights, Delta replacement non-quadbar xenon headlamps, and Bestop saddlebags-Member of the United Four Wheel Drive Association and Blue Ribbon Coalition, †John 3:16†
RIP Mrs. yoda13... My life is better for having had you in it and you made me a better man...I can't wait to see you again...I love you always and forever, and for all eternity
If you want to help the sport of off-roading, and protect your right to do so, please visit the
forum...
yoda13 is offline
post #14 of 16 Old 06-28-2010, 10:09 PM Thread Starter
JK_Jeep
JK_Jeep's Avatar
well I will get a better place align, maybe even the dealer?
I'll get the new tires and follow the tire rotation and see what happens
IT'S A JEEP THING!
JK_Jeep is offline
post #15 of 16 Old 06-29-2010, 01:04 AM
Warlord2
I would get an alignment at an actual 4x4 shop. Also like everyone is saying ROTATE. I do almost every oil change or 5k miles and havent needed an alignment sense I got the lift installed...can also check your brake pads and rotors while your at it!
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
Gearing Upgrade - Parts Advice Needed scottinlina27 TJ Wrangler Technical Forum 12 09-21-2009 07:52 PM
Upgrade your TJ online with performance parts Fear Wrangler General Discussion 3 08-23-2009 08:47 AM
whole new lift? or just upgrade parts? badbidet TJ Wrangler Technical Forum 0 12-22-2007 08:17 PM
Interested in List of Parts for TBI & HP Spark upgrade?? Duneman YJ Wrangler Technical Forum 3 10-13-2007 05:39 PM
