Unplugging wiring harness when removing doors? - JeepForum.com
post #1 of 7 Old 08-06-2007, 07:56 AM Thread Starter
etownjay8
how do you unplug the wiring harness when removing the doors? It looks like you need press down in the middle but its not moving... i don't want to force it and break something. Thanks
etownjay8 is offline
post #2 of 7 Old 08-06-2007, 08:11 AM
hcpookie
Did you read the manual? Not trying to be smart, but it explains it. The red plastic tab is the lock. Slide the tab to unlock it, and the black latch can then be pressed down to disengage. Pull down while pressing the black latch. It is snug but should not require much effort at all.
I just leave my red tab in the unlocked position in-between door removals. The black plastic latch will click when you re-attach it.
FWIW, the plug is called a "wire loom" according to the parts guy at the dealer. He told me that some early JK's had a loom that did not disengage the dome light and "door ajar" switch. My JK, built in June '07, has the correct loom that disengages the "door ajar" / dome light switch.
HTH
hcpookie is offline
post #3 of 7 Old 08-06-2007, 08:19 AM Thread Starter
etownjay8
thanks for the help... where i was looking in the manual, it simply said to unplug the harness. I was messing around with the red tabs but they weren't really moving either... do they just slide left to right?
post #4 of 7 Old 08-06-2007, 08:29 AM
gergy9
Guest
SLide to the side with the the 90 degree tab.
gergy9 is offline
post #5 of 7 Old 09-06-2010, 09:28 AM
j94shore
The manual should state that you have to slide red tab over to unlock. I did place a mirror in the floorboard that was very helpful.
j94shore is offline
post #6 of 7 Old 09-06-2010, 02:32 PM
IndyJpr
Here's a picture:
Slide the red piece in the direction shown using your finger nail (or small screwdriver) on the raised edge. It only slides about an 1/8 of an inch - it is shown in the "unlocked" position. Most people leave them unlocked.
Next put your thumb on the circled tab with your forefinger on the opposite side of the harness. Squeeze and pull the harness straight down - try not to pull on the wires themselves.
Hope that helps.
IndyJpr is offline
post #7 of 7 Old 09-06-2010, 05:32 PM
rubizen
And dont forget once you take the strap off the hook your door moves all the way forward until the mirror hits the cowl. Control your door or you may end up with a dent in you cowl.
For those who fight for it, freedom has a flavor the protected will never know.
rubizen is offline
removing rear windshield washer/defroster harness JohnBarleycorn JK Wrangler Technical Forum 1 04-21-2009 08:19 PM
Wiring Harness AlaskanJK JK Wrangler Technical Forum 4 09-19-2007 11:02 AM
Removing injector harness on 94 4.0L? ExpeditionXJ YJ Wrangler Technical Forum 2 08-14-2007 11:00 AM
Unplugging door trouble. sketch99 JK Wrangler Technical Forum 3 06-03-2007 09:51 PM
removing hard top wire harness sbcvulcan YJ Wrangler Technical Forum 3 08-01-2004 02:11 PM
