unknown tube - JeepForum.com
post #1 of 4 Old 03-26-2020, 06:46 AM Thread Starter
greydragon
unknown tube
I don't know where I should post this. Can any one tell me what this hose is and where does it go to?
This is on the left side of the engine of a 2012 Wrangler.
greydragon is offline
post #2 of 4 Old 03-26-2020, 06:57 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
It's a vent hose, either from an axle or the t-case. It's fine where it is.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 4 Old 03-26-2020, 04:09 PM
222Doc
222Doc's Avatar
Im thinking its from the trans. I moved mine to the fire wall away from the engine. the 3.8s have the same placement of that and when the trans over heated that would spill hot oil and start a fire. The fix on the older years was Limp mode when hot I believe.
The axle ones end rather low under the jeep. I extended those; rear is coming out the rera right corner inside the tub where the wire com up into the tub, fron is as high as the inside of the hood.
222Doc is offline
post #4 of 4 Old 03-27-2020, 06:10 AM Thread Starter
greydragon
OK, thank you for the info, I feel more educated now.
