Turn signal issues - JeepForum.com
post #1 of 13 Old 02-14-2012, 07:32 AM Thread Starter
Angleiron
Angleiron's Avatar
2009 JK Wrangler
Turn signal issues
Sometimes I will get the quick flash on the right turn signal, and then it foes away and the signal operates as it should. I have checked for corroision on the connector and found none. Anyone have a solution to take care of this?
2002 Dodge RT/10 Viper
Angleiron is offline
post #2 of 13 Old 02-14-2012, 07:48 AM
jkirkpatrick
2010 JK Wrangler
You're not talking about the tap turn are you? Tap the lever and the signal flashes three times and turns itself off. Pull the lever and the flash stays on. If this is what you're referring to, it's normal (and in the manual).
If this is not what you're referring to, then I'm not sure what else it could be.
jkirkpatrick is offline
post #3 of 13 Old 02-14-2012, 08:08 AM Thread Starter
Angleiron
Angleiron's Avatar
2009 JK Wrangler
Use the turn signal, and instead of the signal blinking at a normal rate on the dash it is at almost double to rate. When this happens the right front turn signal no longer works. You can drive a few miles, use the same signal and it works normally.
post #4 of 13 Old 02-14-2012, 10:11 AM
ncb
ncb's Avatar
Sounds like a bad bulb. The filament might have intermittent contact. The bulbs are cheap and easy to change.
ncb is offline
post #5 of 13 Old 02-14-2012, 10:11 AM
jkirkpatrick
2010 JK Wrangler
That almost sounds like it could be a bulb issue, or a loose connection on the turn markers on the flares. Who knows, but at least you get a free bump!
post #6 of 13 Old 02-14-2012, 12:56 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
Besides the bulb, it could be an ineffective ground or feed circuit.
JeepCares is online now
post #7 of 13 Old 02-14-2012, 03:12 PM
HappyTrails
HappyTrails's Avatar
I agree with the others, bulb may be burnt out. I've had this happen on other makes of cars and trucks, always the same symptom. Check the filament on the turn signal bulbs. Hopefully, it's just a burnt-out bulb.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #8 of 13 Old 02-14-2012, 03:18 PM
ncb
ncb's Avatar
It's a cheap bulb and only takes a minute to change it. I'll bet a new bulb fixes it.
ncb is offline
post #9 of 13 Old 02-14-2012, 03:54 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2020 JK Wrangler
My wife's gto was doing that on the rear - was a bad ground, the bulb was loose in the socket...
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #10 of 13 Old 04-25-2014, 04:35 PM
Dbres042
2009 JK Wrangler
Similar issue
I have a very similar issue. I've replaced the bulb and the fuse (even though it didn't look burnt, I wanted to be sure) and I still get fast flash. Where is the ground here??
Thanks!
UPDATE: situation is still dire, but I noticed that the flasher operates at normal speed the first time I try it after I start the car, then it switches to double time. Hope this helps
Dbres042 is offline
post #11 of 13 Old 04-25-2014, 04:48 PM
ronjenx
ronjenx's Avatar
I'm curious what fuse you replaced, as the turn signals and left/right rear brake lights don't have fuses.
ronjenx is offline
post #12 of 13 Old 04-26-2014, 07:19 AM
duneslider
duneslider's Avatar
Ronjenx, I am pretty sure there is a fuse associated with the tail lights. Several years ago I was working on some trailer lights and one side wasn't working and I then I noticed one of the rear jeep lights wasn't working and trouble shooting that led me to a fuse.
07 JKU Wrangler
10 XK Commander Limited
duneslider is offline
post #13 of 13 Old 04-26-2014, 02:44 PM
ronjenx
ronjenx's Avatar
Yes, there is a fuse for each tail light. Not for the left and right blinker/stop lights, though.
ronjenx is offline
Right Turn Signal Issues Njordan311 YJ Wrangler Technical Forum 2 11-30-2011 09:36 PM
Crazy Turn Signal Issues cajunjeep TJ Wrangler Technical Forum 5 10-18-2011 11:18 AM
Turn signal issues davis5663 Wrangler General Discussion 1 04-20-2010 05:24 PM
Turn Signal Issues 2k TJ Sport jp32578 TJ Wrangler Technical Forum 3 11-26-2009 07:43 AM
LED turn-signal issues on a YJ JustPassinThru YJ Wrangler Technical Forum 10 07-19-2004 11:45 AM
