Turbo Wrangler-ECU Pinouts. - JeepForum.com
post #1 of 55 Old 02-24-2011, 10:59 PM Thread Starter
infomotive
Hi all. Just finished doing a turbo conversion on an 08 3.8 Wrangler and all looking good. About to wire in a piggy back ECU and would appreciate ecu pinout to save some time. Any help appreciated. Will post picks, results when finished.
Jason
infomotive is offline
post #2 of 55 Old 02-25-2011, 03:55 AM
242much
2009 JK Wrangler
pics first, then pinouts... just kidding man, i'd help you if i had the info. good luck, and don't crank the boost up too high, jk's don't like boost all that much. did you do some headwork and have a custom cam ground as well?
"The stoke was palpable..."
good grief, just buy the Rubicon.
242much is offline
post #3 of 55 Old 02-25-2011, 08:42 AM
MrOrange
2009 JK Wrangler
Maybe RIPPMODS can help? What are you trying to control with the piggyback ECU? I'm guessing the DiabloSport controller may be able to accomplish the same.
http://www.diablosport.com/index.php...isplay&pid=172
'09 X Unlimited, 4WD, auto, half-doors, soft-top
RC 2.5" Series II BB, JKS Quick Discos, JKS adjustable front track bar
15x8 Unique 297 (Soft 8), Goodyear MTR/Kevlar 35x12.50R15
5.13 gears, ARB front locker, Currie front shafts
Bushwacker flat flares, Rubicon rails with steps added
MrOrange is offline
post #4 of 55 Old 02-25-2011, 04:10 PM
Charles
2017 WK
You put a turbo on the Jeep and designed your own software? Dang. Your best bet is to flash the ECU with a DiabloSport instead of piggybacking. Piggybacking is so 2010.
2017 TrailHawk Hemi, Everything but the TV's.
Charles is offline
post #5 of 55 Old 02-25-2011, 04:18 PM
242much
2009 JK Wrangler
242much is offline
post #6 of 55 Old 02-25-2011, 04:27 PM Thread Starter
infomotive
Cheers. No engine std. internally and only running low boost. Will post pics next week.
post #7 of 55 Old 02-25-2011, 04:43 PM Thread Starter
infomotive
Yeah thanks for that. Investigated the Diablosport controller and they told me that would need a custom configuration(obviously) and to contact one of there dealers. Came across RIPPMODS and asked if they could supply Predator with injectors and custom tune based on thier supercharged setup which i figured would be close enough to then trim fuel and ign through Predator. Was informed that tune would be completly different and they dont "tune" by email.
Going to control fuel, ign and boost cont directly thru ecu and if needed add ethrottle module for throttle.
Jason
post #8 of 55 Old 02-25-2011, 04:47 PM Thread Starter
infomotive
Um No. I know that would be the best option but as explained dealer unwilling to go thru process. If it all turns pearshaped will have to get the software and do the custom tune myself.
Jason
post #9 of 55 Old 02-25-2011, 06:36 PM
remery829
remery829's Avatar
pics or it didn't happen
Ryan
vvvthis is what they don't tell you about LCGvvv
...I went with the lcg method but its never ending be because once you fix one thing something else breaks or needs upgrading...
SUPPORT OUR TROOPS
remery829 is offline
post #10 of 55 Old 02-28-2011, 08:49 PM Thread Starter
infomotive
Quick update. Wired and tuned. Slight clearance issue to sort.
Made [email protected] wheels in standard form.
Made [email protected] wheels with 3psi boost. Drives nicely now and should now be a nice tow vehicle for customer.
Will update when reassembled.
Jason
post #11 of 55 Old 02-28-2011, 08:58 PM
Charles
2017 WK
Sweet. Make sure you take pics!
Charles is offline
post #12 of 55 Old 02-28-2011, 11:12 PM Thread Starter
infomotive
Not sure if this going to work but here goes.
Seems i cant post attachments?
post #13 of 55 Old 02-28-2011, 11:45 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
You need to have ten posts to up-load.
You're almost there!
You can link to photo-bucket or another sharing site now or anytime if you like.
Just add img tags and it will show up.
Jim
JLC08JK is offline
post #14 of 55 Old 02-28-2011, 11:51 PM Thread Starter
infomotive
Thanks, thought that might be the case. Will try and figure that out.
post #15 of 55 Old 03-01-2011, 04:06 AM
run11rb
2011 JK Wrangler
Im very interested in pics and info on this build. I hope to do something similiar when im out of warrenty
run11rb is offline
Isuzu 3.9 Turbo Diesel Wrangler MXCarson92 Wrangler General Discussion 14 02-25-2013 12:20 PM
Low pressure pistons? Turbo wrangler UAEjeep TJ Wrangler Technical Forum 10 03-02-2011 02:50 PM
Turbo kit for a Wrangler ronnyi YJ Wrangler Technical Forum 7 01-25-2011 06:30 AM
Turbo Charged Wrangler mikeyz3385 TJ Wrangler Technical Forum 47 07-31-2006 03:14 PM
90 wrangler 38's D44's 390 stroker and turbo 400 springfield45 YJ Wrangler Technical Forum 5 11-04-2002 10:48 PM
