Tires & rims size - JeepForum.com
post #1 of 3 Old 09-19-2018, 01:25 PM Thread Starter
Shadi_obadi
Tires & rims size
Hi everyone,
I've got 35x12.5x20 tire & rim size on my jeep. Are these suitable tires for desert offraoding?
If not any size suggestions??
Shadi
Sent from my SM-N950F using Tapatalk
Shadi_obadi is offline
post #2 of 3 Old 09-20-2018, 08:38 AM
222Doc
222Doc's Avatar
depends on the trails. But over all 20" wheel is a BAD choice for off road. Unless say you are running 37++. 20" wheel will sustain much more damage. the tires 35 and less are just to thin to air down to much. they tend to be wide wheels too. like at least 10" wide where off road you tend to see no more than a 9 or less wide on any 12.5 wide tire.
I live in AZ.
1 at least here in AZ wheeling alone in desert that can reach 120+ is real bad idea. anything goes bad and you may die out there. This happens more than people know. wheeling alone is just not the best idea.
2 Desert wheeling be sure to bring enough water IF say you get stuck out there. Food etc. more over if alone.
If you are in AZ. Join a group or club. There are so many here its easy to do. Those 20"s are expensive wheels and the tires cost more too, a lot. If you really like them maybe get some cheep 17s on a 35x12.5 x17 to use for trails? or just hammer those........ wheels take a lot abuse here in AZ. as do tires. if the rocks dont cut one a Cholla cactus will pin prick them to death in the end.
222Doc is offline
post #3 of 3 Old 09-21-2018, 01:56 AM Thread Starter
Shadi_obadi
Thnx guys for the advice I will try to replace them with suitable size if i found good deal.
