Tire/Rim Fit and Backspace Help - JeepForum.com
post #1 of 4 Old 05-31-2016, 12:20 PM Thread Starter
Decavolt
Decavolt's Avatar
2016 JK Wrangler
Hi guys. Can anyone tell me if the following rims will fit my new tires?
Current tires:
BF Goodrich All-Terrain T/A KO2's - 245/75R/16 on stock 16" rims.
http://www.tirerack.com/tires/tires....omCompare1=yes
New wheels:
Pro Comp 16x8 rim that has a backspace of 4.
http://www.procompusa.com/wheels-pro...o=PXA7069-6873
1) I know the wheels are an inch wider than my stock wheels, but don't know if that makes a different with these tires. Will they fit the wheels?
2) I'm also unclear on backspace. I don't want my wheels to move inward. If anything, I'd rather have them move out by 2-4 inches (or not at all). This is new to me, and I'm not sure if I'm understanding backspace correctly.
and thanks.
Decavolt is offline
post #2 of 4 Old 05-31-2016, 12:53 PM
arbakken
2015 JK Wrangler
1. That is the widest rim the manufacturer recommends. If you look at the specs in the link you posted, you'll see it.
2. That's quite a bit of backspace for those tires, but it's not ridiculous. Stock is 6.25, so you'll get ~2.25" further stickout. The bigger the backspace, the more stress on hubs/bearings/ball joints/etc. It also increases your scrub radius. Ideally, when you increase backspace you do so for a wider tire. Most aftermarket wheels for JK are 4.5
arbakken is offline
post #3 of 4 Old 05-31-2016, 01:46 PM Thread Starter
Decavolt
Decavolt's Avatar
2016 JK Wrangler
Thanks arbakken.
So it sounds like I'd be better off with something with zero offset, maybe these:
http://www.autoanything.com/wheels-r...s-alloy-wheels
The only question there is that the wheels show a "recommended" tire size of 245/70 and I have 245/75. Would I run into any issues there?
Decavolt is offline
post #4 of 4 Old 05-31-2016, 02:41 PM Thread Starter
Decavolt
Decavolt's Avatar
2016 JK Wrangler
Thanks arbakken, that's helps quite a bit!
Decavolt is offline
fitment , tires , wheels
