tie rod question - JeepForum.com
post #1 of 10 Old 08-01-2011, 06:19 PM Thread Starter
nj-rubi
tie rod question
Guys
Just went over the new lift. I tightened all bolts and torqued the tie rod down to 130ft lbs. one thing i noticed is that i can take the tie rod and move it? or should i say twist it up and down. It is moving in the ball joints. jeep has just under 14,000 miles.
Is this normal?
thanks
Joe
nj-rubi is offline
post #2 of 10 Old 08-01-2011, 06:45 PM
Prot
Prot's Avatar
2014 JK Wrangler
Most people say as long as it does nit move side to side it is fine. A few years ago my steering was sloppy as a whore. Everyone told me my tie rod was fine despite it being so bad that a sneeze would cause it to flip. I replaced it with a chromoly unit from Polyperformance and it is infinitely better.
JK's have notoriously crappy ball joints, tie rods, and stuff like that.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #3 of 10 Old 08-01-2011, 06:50 PM
1222
RIP John
1222's Avatar
Prot, how long has it been since you replaced your tie rod and is it still tight or is it starting on the way to sloppiness. I need to address mine soon because itís bugging the heck out of me.
1222 is offline
post #4 of 10 Old 08-01-2011, 07:10 PM
2002Jeepdad
2002Jeepdad's Avatar
2016 JK Wrangler
I've got a 2010 Islander (Unlimited) with 30k km (18K miles), and my tie rod I can move around with 2 fingers( rotating it). Was told by dealership it is normal, they can change it, will be stiffer for a bit, but will be the same in no time. They did change the stearing stabilizer (they call damper)....I didn't feel that part to be an issue, and has made no difference in the stearing to me. still gives the clunks and clangs every so often in front.
Live Long, Jeep Naked!
2002Jeepdad is offline
post #5 of 10 Old 08-01-2011, 07:48 PM
RockyClymer
RockyClymer's Avatar
I am glad you torqued the tie rod down, but did you torque the track bar as well?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #6 of 10 Old 08-01-2011, 08:27 PM
Prot
Prot's Avatar
2014 JK Wrangler
It is still tight. I think it's been about 2.5 years. I was so impressed with the product that afterwards I bought a high steer kit from Polyperformance which further enhanced my steering and gave me parallel geometry.
Both items are money well spent on a lifted Jeep due to the craptastic nature of the original parts.
Prot is offline
post #7 of 10 Old 08-02-2011, 04:36 AM Thread Starter
nj-rubi
yes. that has not loosened up at all, since the install.
guess the ball joints are the way they are?
nj-rubi is offline
post #8 of 10 Old 08-02-2011, 04:48 AM
Jeepin_Dad
I Like TATAs
Jeepin_Dad's Avatar
Mine have gotten to the point where if I twist it up it swings down under it's own weight. I'm waiting on my new Rock Krawler tie bar to show.
8th Annual Topless For TATAs
August 12, 13 & 14, 2016 at Rausch Creek Off-Road Park
Jeepin_Dad is offline
post #9 of 10 Old 08-02-2011, 10:08 AM
1222
RIP John
1222's Avatar
Originally Posted by Prot View Post
It is still tight. I think it's been about 2.5 years...
Thanks. Now I know what to get when the time comes. I was hesitant to replace mine thinking that in a few months it would just go back to being sloppy like the factory one.
1222 is offline
post #10 of 10 Old 08-02-2011, 06:28 PM
Warlord2
New tie rod also fixed my wobble issue. Im very pleased with the poly performance tie rod as well, already bent it up a little but it was easy to address with the on the fly adjustment. VERY convenient for fixing the alignment after leaving the trail. Rock Krawlers was my first choice but the cost difference and shipping time was a factor so I went with polys (glad I did). I will know how well they hold up once the 37" iroks and hydro assist steering get installed in the coming weeks.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
Lift/Tires question and Cleaning soft top & engine question Bryan_16 TJ Wrangler Technical Forum 16 05-19-2012 03:25 PM
Front sway bar question + bonus disco question WranglerTom TJ Wrangler Technical Forum 7 12-02-2011 08:13 AM
drag link question, and also tyre sizing question snowmanbud TJ Wrangler Technical Forum 3 11-21-2010 07:38 AM
1988 carberator question and wiring (general) question prljeep YJ Wrangler Technical Forum 15 05-08-2009 11:50 AM
Tire question(noob question but just a quick answer needed) 07SilverX JK Wrangler Technical Forum 3 12-25-2007 03:35 PM
