Strange Vibration NEED HELP - JeepForum.com
post #1 of 13 Old 02-16-2013, 02:13 PM Thread Starter
Danzy55
I have a very strange vibration in my 2010 JK Sahara. Only happens in 1st or 2nd low speed. Weird vibration noise seems to be coming from the center stack or from the driver or passenger foot well area.
IF THIS HAS HAPPENED TO YOU PLEASE TELL ME It can drive you insane!! See clip below you can hear it at 0:06/ 0:17/0:25/0:31/0:45-48
Thanks
Shane
http://www.youtube.com/watch?feature...&v=ZIqSQAJaJi0
Danzy55 is offline
post #2 of 13 Old 02-16-2013, 02:33 PM
Tanimal
Tanimal's Avatar
Sounds like the brakes/rotors to me? Maybe front drive shaft but I'm just guessing at this point. Any lift on the Jeep? Miles?
Learning as I go and it's worth every penny!
Tanimal is offline
post #3 of 13 Old 02-16-2013, 02:41 PM Thread Starter
Danzy55
37,000 miles, no lift bone stock....strange only hear it normally when its warmed up and when stopped shift into 1st let out the clutch you hear it then shifting into 2nd again same vibration then its gone once your up to highway speed not a damn thing.......bizarre.
Danzy55 is offline
post #4 of 13 Old 02-16-2013, 03:38 PM
toxicwaste29
Maybe a heat shield under you?
toxicwaste29 is offline
post #5 of 13 Old 02-16-2013, 04:40 PM
gcan
ur brakes & rotors can be possible. ur rotors warp in time. it can be be ur transfer case gears if ur in 4x4 when it happens. it can also be cv joints yet that would be more at high speeds.
when u brake does ur truck vibrate?
also check ur uv joints. see if u can move ur drive shafts. u should not be able to @ all.
check tires by moving side to side or top to bottom if top to bottom its cv joints, side to side its tii rod ends.
good luck...
gcans other half (myk)
gcan is offline
post #6 of 13 Old 02-17-2013, 09:06 AM
GPV
Do you hear when only when you operate the clutch?
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline
post #7 of 13 Old 02-17-2013, 11:09 AM Thread Starter
Danzy55
if your at a light then let out the clutch and start moving the rattle noise is heard depress the clutch to go into 2nd no noise let it out and the rattle can be heard for a second or two tops then it goes away.
The brakes/rotors are good, front end is nice and tight. Just a bizarre noise sounds like the heating vent is rattling around or something......dropping it into the dealer to give it a once over.
Dealer tech thinks it might be a body panel loose.......??
Since the noise is coming from the center stack footwell area under the glove box maybe a heat shield or something is rattling around but you would think it would be present all the time.
Danzy55 is offline
post #8 of 13 Old 02-17-2013, 02:14 PM
thedirtman
thedirtman's Avatar
Check the heat shield on your exhaust cross member. If that spot weld breaks it will give you a little vibration under the foot wells.
If you learned something new today, you had a good day.
thedirtman is offline
post #9 of 13 Old 03-06-2013, 10:55 AM Thread Starter
Danzy55
Well got back from a trip picked up the Jeep no noise.....told me the inner fender was loose and not lined up properly. So far so good no noise. I did have the fenders repainted after I bought due to some crappy Jeep paint job under warranty guess the dealer didn't tighten them down or something.
Danzy55 is offline
post #10 of 13 Old 03-06-2013, 01:32 PM
brianjw
My front inner fenders were loose from the factory. The top bolt in them is tightened all the way but the inner fenders still moved around on the top, and on the back they flapped around and hit the metal body. At freeway speeds you'd hear stuff flapping around underneath. Just piss poor design, but easily fixed with a few zip ties.
brianjw is offline
post #11 of 13 Old 03-23-2013, 01:28 PM Thread Starter
Danzy55
finally figured out the noise. I installed a K&N cold air kit, the end of the air filter is a metal housing, it was just close enough to the frame of the Jeep that when you started moving the stress from the engine would cause it to vibrate thus touching the frame and that sent that noise right into the dash area......Thank heavens.....I was going mad with that damn noise.
Danzy55 is offline
post #12 of 13 Old 03-23-2013, 01:37 PM
Tanimal
Tanimal's Avatar
Damn CAIs! Never hear anything good about them.
Tanimal is offline
post #13 of 13 Old 03-23-2013, 01:46 PM Thread Starter
Danzy55
I know.....felt like a real ***! Funny thing was the Jeep dealer swore it was my inner fender liners....gives me a warm and fuzzy feeling if I ever have a real problem.
Danzy55 is offline
