Stereo Replacement CANBus Question - JeepForum.com
post #1 of 5 Old 04-09-2014, 10:13 AM Thread Starter
Double_DD-s
Double_DD-s's Avatar
So I decided to sell my RER factory Nav. unit and replace the system all together. I have (had) the INfinity + RER system. 08' JKU
So here is my question. What happens to the CANBus system if the harness that plus into the stock deck remains unplugged?
If I run ALL new wires for power, ACC, ground and speakers, I can just leave that wire harness there, unsused. Will it cause and Check Engine Lights, etc???
Double_DD-s is offline
post #2 of 5 Old 04-09-2014, 11:47 AM
222Doc
222Doc's Avatar
all the warring systems use the speakers to work. so i would think it might toss a code. they do make a box so that your funtions for the steering wheel and other systems tie in.
222Doc is offline
post #3 of 5 Old 04-09-2014, 06:01 PM
maniacal_rick
maniacal_rick's Avatar
I replaced my entire system. I didnt have the Nav, so I dont know if the 130 tied into the CANbus system...however eveyrthing works like a charm. My build thread has all of the parts I used.
2012 2Dr JK - Metalcloak - Currie - Prorock - ARB - Poison Spyder - RCV - Synergy - Etc...
maniacal_rick is offline
post #4 of 5 Old 04-09-2014, 06:02 PM
maniacal_rick
Here are the numbers:
Standard Double Din Dash Kit
Wiring Harness - XSVI-6522-NAV (Metra)
Steering Wheel Control Interface - ASWC (Metra)
post #5 of 5 Old 04-13-2014, 10:50 AM
jm708
2014 JK Wrangler
I also went with the wiring harness and steering control interface. Easy install...
jm708 is offline
